Bosal Bike Carrier (1 Viewer)
Clickem
1,034
1,073
Northumberland
None
7 years
Need a bike carrier to go on a tow bar and carry two electric bikes
Like the look of the Bosal range, who have two offerings of interest. Traveller II Compact at around £325 and the Tourer II at around £240. The Traveller II seems to be easily available, but I can only find the Tourer II on Bosal's UK website or Amazon in Germany
The only difference that I can see between them is that the more expensive Traveller II has a pedal to tilt, while the cheaper Tourer II uses a handle - we don't need to tilt anyway
Anyone using or have any knowledge of either of these two models?
TIA
Minxy
32,651
66,541
E Yorks
Carthago Compactline
Have you checked what weight your towball can take first as 2 electric bikes and the carrier can weigh a bit, also your rear axle loading needs to be considered too.
Clickem
Clickem
1,034
1,073
Northumberland
None
7 years
I have 700kgs of spare payload and a similar amount could be added to the rear axle
The tow bar I intend to use, a Witter, is type approved for my van? Total weight for bikes and carrier will be about 60kgs. Where can I find the "nose weight" for the tow bar/van?
Teuchter
Nov 4, 2014
1,404
4,001
Lee on the Solent
Hymer Mercedes MLI 580
I have been caravanning for 32 years but in 2014 I have"gone over to the dark side"
The "nose weight" for the tow bar will be in excess of 100 Kg. as for the acceptable tow ball load on the van this will depend on the rear suspension set up but as most saloon cars have a 60 to 90 limit and my merc 270 cdi 4x4 had a 150 Kg limit then your van which is based on a commercial vehicle chassis will probably be in excess of that.
The actual figure for the towbar assembly complete will be stated by Witter and the van figure will be hidden somewhere in the vehicle spec details but at 60 Kg - worry not"" :)
