Bonding Onto Roof
Discussion in 'Motorhome Accessories' started by Daveymac, May 5, 2015.
  1. Daveymac
    Daveymac Funster
    Oct 6, 2014
    4
    Kent
    Hi has anyone used Sikaflex or Dekasil bonding to fix Satalite dome or solar panels to their roof or anything else for that matter and if so which would you recommend Sikaflex or Dekasil, please
  2. rosalan
    rosalan Funster
    Jul 12, 2013
    984
    805
    Beds
    Based only on my own van and fairly wide reading, there is a Sikaflex that seems to be used by most tradespeople. To date I have not heard of any failures for securing items onto van roofs, providing it is given enough time to cure.
    • Like it Like it x 1
  3. musson
    musson Funster
    Dec 25, 2013
    425
    145
    grantham
    Fitted both solar panel was fitted with sikaflex only,I was advised to use sikaflex and self tappers one in each hole in the satdome feet (4)
    by the engineer that fitted these to my first van reason he had experience off sat dome coming off roofs,make sure when you fit the screws (if you do) that you fill the hole with siklaflex before you put screws in the cover the screw when fitted.mark out with masking tape where you are going to fit them on the roof make sure they clear everything,clean the roof with a non residue cleaner (I used alcohol wipes) let it dry and use siklaflex as instructions.
  4. Daveymac
    Daveymac Funster
    Oct 6, 2014
    4
    Kent
    Thanks for that peeps I will take it on board.:)
  5. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    3,039
    2,816
    Englishman in Mid Wales
    Sikaflex only on my solar panels and they haven't fallen off yet(y)
    But I have no doubt that other company's make comparable products:)
Similar Threads
  1. The Spongebobs
    353
