Bodywork finish on a Hymer A class (1 Viewer)
hymerhobo
14
West Midlands
6 years
Having been quoted 800 quid to repair a small dent and a hole (courtesy of motorist who reversed into the side of my B694 two years ago in a carpark when I was away from the vehicle) I took the decision to do the work myself. Now, after a long process involving Plastic Padding, fine filler, various grades of wet and dry, etching primer, acryllic undercoat, and finally several coats of Fiat Biano 210, the result (I'm relieved to see) isn't too bad. The colour match is surprsingly good, and after a final go with 1200 grade, the finish is pretty flat. However it isn't quite as glossy / smooth as the original. So before I get the T cut out, can anyone tell me whether A-classes generally have a coat of laquer on top of the paintwork? Many thanks ...
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
dont know the answer .but i normally use two pack acrylic .polish from a gun finish. only use wet n dry if there is a sag or run . best not to wet n dry ,sometimes can have a slight orange peel but it settles down after a while. get agraphic done if it bothers you. talk to a sign writer shop .they do nice little disguises if you tell em what you need. or put a sticker.
43,329
49,444
no expert on paintwork but i do know if something has a laquer coat and it gets damaged, in time the laquer will start to 'lift' and you will see it.
final coat and a final 1200g wet'n'dry rub over....no wonder its a bit duller.:RollEyes:
final coat, leave for a week to really harden then gently 'T cut' it.:thumb:
Lenny HB
53,430
150,000
On the coast in West Sussex
Hymer B678 DL
The outer body panels are made from pre-coated aluminium sheets it not a normal paint finish as we know. All you can do is try different finishes until you get the best match.
I would have thought a levelling spray would be your best option they are like a clear coat with a slight tint designed to blend in old & new paintwork not normally available from retail outlets need to go to paint supplier that supplies body shops.
