Blender To Run On Inverter (2 Viewers)
mwark
93
37
London
Looking
Newbie
Hi,
Does anyone run a blender (handheld or otherwise) on an inverter? Can you recommend one? My partner and I make a healthy smoothie every day for breakfast and would like to be able to do this while on the road.
tonka
10,833
21,532
Cannock, Staffs
A class Burstner 800
Since 2000
Dont have one myself.
I would have thought a hand blender for easy of storage..
A quick look and Argos do a cheapie at £6.99 thats 160 watts..
Some of the better ones run at 300+ watts !
You only run them for a minute or two so should not be a problem just get a big enough inverter and make sure your batteries are ok..
Broken Link Removed
mwark
mwark
93
37
London
Looking
Newbie
Thanks. So from research, any blender less than 300 watts should be ok? We add nuts to the smoothie so need something that is at least slightly powerful.
Welsh girl
3,658
3,036
Globecar
Since 2004
I make soup with my 160w with my blender from the inverter. Its only on for a few seconds.
It's a 300w inverter.
tonka
10,833
21,532
Cannock, Staffs
Since 2000
My maths says a 300w blender, hand or proper one.. Will take about 25amps. But as it only runs for a min or two thats about an amp... So no massive drain on the battery.. But you need a good sized inverter and wired direct from the battery. One that plugs into a cigarette socket will be no good..
mwark
mwark
93
37
London
Looking
Newbie
Thanks!
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Solar ,2x 110a batteries haveing a 1500w inverter runs the microwave fine ,and I have a nutribullet 600w ,use it with no problems , makes good smoothies etc only on for less than 1 min :)
mwark
mwark
93
37
London
Looking
Newbie
Btw, I have solar, 2 x leisure batteries, 600W Nikkai inverter.
Ethle the wondervan
199
646
Peak District
One year
A BLENDER !!???!!
Chew thoroughly and spit into a bowl
Repeat several times until you have sufficient quantity
This way you enjoy it twice without wasting lekky
Huh! Beginners, who'd 'ave 'em.
Feb 19, 2015
1,776
1,249
Norfolk
Globecar Campscout 2013
Since 2016
Did anyone find a good 12 volt one? still searching #
thanks
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
or a good battery one or even a hand one. I ordered one that you pull a rip cord to spin the blades but its not arrived in time and was only £8 so most likely not good.
JJ
Mágica
May 1, 2008
19,259
48,046
Burstner Privilege T
over 50 years
Beware... some of my low wattage kitchen appliances need a pure sinewave inverter to run and some don't...
Just saying...
JJ :cool:
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
My mum made do with a hand driven one. Bloody modern kids etc....
I'd happily have one but can't find any!
I should've said we don't have an inverter just 12v sockets. Looking for a battery driven or rechargeable ideally
Oct 1, 2013
7,512
19,938
Lanzarote
Nil by mouth
Lots
Loads here:)
Broken Link Removed whisk rotary&biw=457&bih=628&source=lnms&sa=X&ved=0ahUKEwiZv5fmu6DPAhUGVRQKHf8gBFUQ_AUIBSgA&dpr=1
havevan_willtravel
Solar ,2x 110a batteries haveing a 1500w inverter ... nutribullet 600w ... no problems
Do you mind posting what type of inverter that is? I have the same setup but with a 1000w inverter and the nutribullet draws too much power (actually basically everything seems to draw too much power for the inverter so looking to swap it out). Better half's morning smoothies are the key buying criteria...
Oct 1, 2013
7,512
19,938
Lanzarote
Nil by mouth
Lots
You'll need one of these
And one of these..
Place fruit in object B. Then smash with object A
TerryL
6,187
8,190
North East
Low Profile
Just read an article (Readers Digest) that says smoothies aren't very good for you. The ingredients as they are, or perhaps chopped, are much better as making them smooth destroys all the fibre. So save yourself some money for the healthier things in life. The best "smoothies" come in bottles - well grapes are a natural ingredient aren't they? :D
Basildog
2,208
3,590
Hi,
Our Hymer actually has a special drop down cupboard for a blender/liquidiser as most Hymer owners are so old they have lost the ability to eat solid food (y)
JackieP
666
1,400
Isle of Man
Since 2006
I used a Nutri bullet with a 1500 watt inverter (until the fire brigade arrived)
Now I have a 300 watt inverter with a Magic Bullet and it’s absolutely marvellous. It chops nuts and ice and I can also make flour and nut butters. Reasonable price on amazon too. I’d suggest the smaller cheaper version as it has less accessories and so easier for packing away in the van.
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
No problem with running a blender from an inverter but why a smoothie, turning wholesome fruit and vegetables into a disgusting slime, while destroying the beneficial fibre.:sicker:
Oct 1, 2013
7,512
19,938
Lanzarote
Nil by mouth
Lots
The fibre doesn't get trashed any worse than chewing.
And some folk advise that the goodness is absorbed into the body faster.
TerryL
6,187
8,190
North East
Low Profile
Agree about absorption but I could argue that fibre is needed to aid the digestive process, or so the medics tell us. Chewing doesn't break stuff down as much as a blender.
