Black Streak Remover (1 Viewer)
Redjumpa
148
44
North Lincolnshire
5 years
I have a 1991 Hymer with the "Orange peel" finish (see pic below)
Over the winter black streaks have appeared on all sides of the van. No problem I thought and attacked it with "Fenwicks Black Streak Remover" but it hasn't even touched it. Has anyone had any success cleaning this age (and rough finish) of van? if so what can you recommend?
Theonlysue
6,105
7,385
Essex
As Executive 50th an
Not long enough!
Hi, have you tried 'Showroom Shine/Greased lightening '? You can order it on the shopping channel on the internet Ideal World.
Its about £30 for 3 Litre, and it has no problem with the streaks on my van.
S
Redjumpa
Redjumpa
148
44
North Lincolnshire
5 years
S
Thanks for that, I'll have look.
I'm guessing your van is a nice smooth shiny type, I think that is maybe the issue for me. But I could be wrong, I'm relatively new to this!!
Sep 27, 2007
837
289
Shropshire based
Globecar
started in 2001
Hi Redjumpa
This offering from John on our sister forum, may be of interest to you. It employs eveyday items which will not break the bank.:thumb:
Nomadic
"The Hymer S700 is a one piece fibreglass moulding.
I used to sell caravans and when I got a very dirty van in I would wet it and then spread Domestos on the roof and walls. I then left it for a while to work then washed it off. I finished off with a wash with a Flash solution then a good rinse. Worked every time.
I have used a not too hard brush to clean the sides of my 1992 Hymer S700 with no problems.
John"
motor roamin
May 23, 2010
1,541
792
Leicester
2 mins
As for those black streaks and stuborn mould, I think I have bought every product known to man and possibly more, I have enough to start my own market stall Link Removed any way the best thing I have found and it is very good is Bio Pro wash n wax caravan and boat shampoo, it goes a long way it works, I usually buy it at the shows from Dave the whole product range (apart from the glass cleaner) is superb and does what it says on the tin, they are in Ashbourne Derby 01332 824848 cheaper at shows but if you need it well worth a call.
I have no connection with this company at all, but all donations gratefully received for all the crap I bought at great exspense to find a good oneLink RemovedLink Removed.
All the best Rick
43,392
49,853
i got fed up fighting the black streaks with so called streak removers so a GENTLE application of T cut followed by wax did the trick.
motorhome was smooth panelled and white gel coat so no paint to rub through.
Jim
Ringleader
Jul 19, 2007
36,541
131,651
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I just discovered the best thing for black streaks. My new ( old) Hymer has a gutter on three sides that takes any water from the roof straight to the floor. It looks like a small awning channel; it works, no black streaks::bigsmile:
big map
4,597
182,356
Poole
Since 2009
We used to have a caravan with the same finish. I found the Black streak remover worked well if you aggitated it with a small soft brush. I used a clean shoe polish brush and worked on about a two foot square area at a time.
Mike.
Redjumpa
Redjumpa
148
44
North Lincolnshire
5 years
Mike.
Just what I thought, I did it exactly as you suggest, but no joy :Sad:
Redjumpa
Redjumpa
148
44
North Lincolnshire
5 years
Hi Redjumpa
Nomadic
John"
Hi John
Is "Nomadic" a link coz if it is I can't get it to work.
Cheers Graham
BionicPixie
205
41
non
i had some black streaks and black in the hinges of the cabinet on the side of my beloved Matilda (my motorhome known at a lot of race circuits); nothing could shift the remnants.
Chatting to one of the SuperLeague car teams in the pits at Silverstone (as you do) I mentioned this and he suggested Bounce tumble drier sheets! :ROFLMAO:
Chatting a few months later and stains darker I was discussing the merits of a good gleam on an old car as the team were clearing the remains of several swarms of insects in a hot sun (not pretty on a white jag!) again in the pits and paddock he too said Bounce sheets.
A firm disbeliever I went and got a pack .... a dab a water and a gentle rub and sure enough all of the black has gone; even inside the hinges!!!! OK it took a couple or three rubs and about ten minutes; but theyhad been building up for over a year and various attempts to remove them had failed!
impressed .... my pressed had not been so immed in a long time!:ROFLMAO:
My beloved Matilda has a loveerly perfume too!!! a quick dab behind each wing mirror when going out.
So Bounce sheets have the professional car cleaner approval as well as mine!
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
The fenwicks black streak remover is a pre watered down version of the motorhome cleaner use the motorhome cleaner 10to1 or even neat on a sponge and wash off straight away halfords sell this motorhome cleaner as well as dealers shops
read this review
http://www.fenwicks.info/news_and_reviews.htm
I also use this watered down on my alloy wheels as it shifts brake dust etc really well and does not damage them
Jan 11, 2010
2,757
9,620
Chester
Auto-trail
Well that`s our 13th year & still loving it.
cleaner
We used "Muc Off" on ours came up like new, well recommended. :thumb:
JockandRita
11,488
150,408
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Hi Graham,
I use Traffic Film Remover (Traffic 110 + Wax), which is produced by Image Chemical Products, and I purchase it from P G & C Nottingham in a 5ltr container.
I wet the bodywork, apply a diluted solution from a spray bottle, and I brush it into the paintwork, rinsing off immediately. On really stubborn stains I use it neat, but again, rinse it off immediately. I do this in stages, rather than all at once.
This is never carried out on a sunny day, as if left to dry, it will stain the paintwork/fibreglass, and only a good polishing will remove the staining...........writes he from experience. :Doh:
Autosmart will no doubt do a similar product, and may be closer to you on the Humber.
HTH, :thumb:
Jock.
John & Joan
1,425
774
Darlington
10 years this time
Hi John
Cheers Graham
Hi Graham
No, Nomadic is another member who saw my post on Motorhome365 Association (website for Full timers) and reposted it here.
I got a bit enthusiastic with a T Cut type cleaner while trying to shift these stains and the dimples went on one place, while trying to remove the stain. They are plastic not paint.
The black comes from the rubber trim, so getting that clean and waxing it, will cut the black streaks down considerably.
I still believe in neat Domestos to get rid of green mold and around the rubber trim, then finish with neat flash liquid to get dirt out of the dimple finish. I used a soft but stiff scrubbing brush to do this. Then wash the van in the normal way with a flash in water solution. Then a good swill with clean water.
I polished the van in May last year with Autoglym and it still doesn't look to bad. However the van has been in mainly dry Spain this winter.
Hope you get it clean.
John
zaskar
1,159
371
UK
5th Wheel
Save your brass and just use ordinary household bleech on a cloth. It should do the job.
Just be carefull if you get it on any graphics and wash off with cold water A.S.A.P.
A great many of the "wonder cleaners" are not what they're cracked up to be and cost a bomb.:winky:
Jun 2, 2010
4,924
11,292
Flintshire
Low profile
since 2010
S
I,ve tried this and it really is a wonder polish, however I think it's overspecified for what you want (it's marketed as a waterless cleaner) and therefore overpriced, especially when my wife found it worked wonders on shower cubicle glass, she used it on all the glass in the house and it really did become expensive. For black streaks I get a tub of 'Silky' from the local accessory shop and find it works wonders 2 or £3, last time I bought some there was also a new improved formulae in a pump dispenser that included wax but in my opinion was not as good as the original Silky.
Redjumpa
Redjumpa
148
44
North Lincolnshire
5 years
UPDATE...........
Well, after spending months, and a fortune trying to solve the black streak problem (and thanks for all the suggestions) It has finally been solved using CILLIT BANG!!
Just have to make sure it is rinsed off quickly.
I couldn't believe it after all the specialist products proved to be no good at all.
Nov 30, 2009
6,548
149,250
Pickering
PVC the PUG
We use silky for the streaks too.
Feb 1, 2011
209
146
Redcar
Hymer C. Class
26 yrs
About a year ago we found the magic cleaner 'Elbow Grease' stocked by Yorkshire Discount, Boyes, most decent hardware shops and many Pound shops and YES! priced at
ONE POUND, it is chemical free, the main ingredient, Lemon Juice.
I totally cleaned a 36' Static (untouched for a year) in 2 hours.
A brilliant piece of kit, it will clean the finest fabrics without any harm.
Black Streaks on the Van are a thing of the past, we use it outside and inside on all surfaces. It is a winner.
Best Regards, Mac
Glynn
163
18
Lancashire
We have a product that removes these black streak marks simply by spraying on and wiping away with a piece of terry towel. We can bring some to the bring & buy meet.
It has never failed us yet at removing black streaks.
Erindoors uses it on a multitude of things in the MH and at home and it's eco friendly and non toxic & non solvent.
staging lady
1,131
55
North Wales in the Hills
6 years but caravan owner in past
We bought a tub of Pampervan at the Peterborough show and so far I'm impressed. It's non toxic,biodegradable,a seaweed base I believe.
Been using it today on MH upholstery- good, flies streaks and blood,wings, all on bonnet -amazing cleared the lot. Due to do streaks next.
Link Removed This is the firm.
Lucille
Drifter 390
Exeter
Compass Drifter 390
Since 2000
Hi Glynn,
Sorry to trouble you but could you possibly let me know what product removes black streaks with a spray on and wipe off solution? I have tried and failed to solve this problem over many years (20!). Despite this, I have to follow up any lead and I'm hoping that you might share your secret with me so that I can actually look forward to cleaning my Compass Drifter 390 one again. I would for ever be in your debt.
Kind regards, Alan Spring.
P.S. Do I have to register to be able to see your reply? Thank you for your help.
Apr 26, 2015
2,806
6,964
Ottershaw
Hymer S820
First motorhome May 2021
Hi Alan and welcome, the post you are referring to is from 2011, Glynn appears to be a free member so may not be able to reply to your question. Maybe someone else may know a product which will do the job and will be along in a minute to tell us.
Drifter 390
Exeter
Compass Drifter 390
Since 2000
Thank you ChrisL.
I have quite a few to try, in particular the bounce sheets. I will also be interested in any other suggestions. I'll keep searching but I'll will let you know which works the best.
Regards,
Alan, I mean Drifter 390, which as you may have guessed is the make of my motorhome!
Nov 17, 2012
1,931
2,614
WEST SUSSEX
HYMER B SL 674
SINCE 2005
Our issue is the rubber trim seals that separates (or joins) the main aluminum panels on our Hymer. Really blotchy black in places. Told brake cleaner was a good solution?
