Binocular recommendations? (1 Viewer)
Jun 30, 2011
7,267
20,240
Barnard Castle, UK
Concorde Concerto
A good quality pair for birdwatching, nature.
Anybody recommend a decent pair please.
We live up on the moors it's like a giant nature reserve, it's a crime not having good binoculars.
andy63
4,672
15,018
south shields
since 1990
I got Bushnell.. not cheap but very good.. lifetime warranty withvany defects..
Andy
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
The starting point is budget. Binoculars range from under £100 to £2,000. Broadly speaking for decent nature watching you need 8 or 10 times magnification by 32 or 42 mm objective lenses. 8x42 will give you better light gathering but are a bit heavier than 8x32. Having said that, the best 8x32 will beat a cheap 8x42. The apparent advantage of going up from 8 to 10x magnification has to be balanced against the fact that it is easier to hold the 8x steady, thereby getting a crisp image.
If you have to wear glasses then it can be an advantage to get binoculars that allow you to keep your glasses on. If this facility is needed then make sure the binoculars have decent ‘eye relief’, that is the distance that the pupil can be from the eyepiece. Look for a figure of at least 17mm, ideally more.
Broadly speaking, you can divide binoculars into three quality bands (leaving aside the real cheapos). Around £200-£500; £500-£1,000 and £1,000 plus. Three premium brands dominate the top end, the so-called ‘alpha bins’, Leica, Swarovski and Zeiss. Leica and Zeiss also make excellent products in the middle range. At the bottom end there are loads of brands but many of them are made in China, not necessarily a problem but be careful when choosing.
Other good brands to consider in the mid/lower ranges: Opticron, Vortex, Hawke (made in China) Kowa (mid to upper), Celestron and Bushnell.
Ultimately, you must try before you buy and try to do it in poor weather rather than on a clear sunny day. I have heard a story of a high-end brand rep referring to bright days as ‘crap telescope days’ because under those conditions even a crap scope can perform ok. In poorer conditions, the quality of better instruments shines through. Try to do your testing in realistic outdoor conditions, not in a showroom. Better dealers will have this facility.
Hope this helps and ask any more questions as and when they arise.
irnbru
13,519
31,159
Glasgow
Benimar 264
11 yrs
Andy
I wouldn't expect any less from you. You dont know what cheap means and only go by price tags :LOL::LOL::LOL:
MikeD
3,936
3,697
London
IH PVC
If money is not an object then I consider Swarovski are pretty good. (y)
JeanLuc
3,304
2,199
Warwickshire
Swarovski are excellent but they don’t make anything under £1,000 apart from a couple of compact designs and they are a bit limited regarding field of view and light gathering. Their 8x32 and 8.5x42 EL products are outstanding but they are c. £1,500 and £1,825 respectively.
Jul 29, 2013
9,089
18,833
Salisbury
Hymer B678DL A class
Vanguard are very good at a reasonable cost I’ve been using them for many years and they have a lifetime guarantee.
andy63
4,672
15,018
south shields
since 1990
Cheeky git... im a poor pensioner..:D
If you want quality you generally have to pay the price...
Youer catching on slowly...but have a ways to go yet(y):p
Andy
18,072
48,328
Another factor to consider is size. I inherited a pair 10 by 40B binos which are superb especially in low light levels but they are not something you can pop into a pocket. So a year or so ago I bought some Zeiss 8 by 20s which in normal daylight are very good, the only disadvantage is the reduced field of vision. Their big advantage is they are so light and small they can be tucked into a shirt pocket so you never have an excuse not to have some binos with you. You can have the best and biggest binos but they are not much use if you left them at home. :)
irnbru
13,519
31,159
Glasgow
Benimar 264
11 yrs
Andy
Dont start me :mad::mad::mad::mad::ROFLMAO::ROFLMAO::ROFLMAO:
Feb 9, 2008
4,097
5,931
SW Scotland
LP Coachbuilt
8x32 will slip into a jacket pocket and should do the job. I use Zeiss.
A good quality pair for birdwatching, nature..
Big is Beautiful.
The more light you gather the brighter the image will be. A guide is lens size divided by magnification. 50 / 8 = 6, 25 / 8 = 3 which will be much dimmer. I have a pair of 15 x 75 which are positively dazzling but too heavy to hand hold. I've seen 60 x 50 advertised, they would so dim you'd see little.
Don't even think of zoom. Too many pieces of glass involved.
My favourite size is 8 x 50.
After that it's down to quality of manufacture which shows in the price.
dabhand
4,310
23,942
Staffs
Concorde carver E35
Since 1993
https://www.bestbinocularsreviews.com/binocular-awards-2018.php
I went on safari 20 odd years ago and asked for a reasononable pair of bins for to see the animals, I ended up with Fumoto horizon 10 x 50 at around £100, still got them they still seem ok to me, but I would never argue with people that know, like some of the above, whether my eyes would tell the difference between a hundred and a thousand pounds I will never know until I get to see through a pair of the really expensive ones!(y)
CazPaul
Jun 30, 2011
7,267
20,240
Barnard Castle, UK
Concorde Concerto
Thanks all, I have been a keen birdwatcher all my life, need a decent pair.
Suppose it's like motorhomes, do I go for cheap, mid range or high end, would love high end but can't justify the price. Wonder if any used high end ones around?
Oct 8, 2009
487
354
Kent
Sunlight
32 years
I do a lot of hiking and used to carry a pair of compact binoculars for weight and size reasons, but as others mention above the compromises were too great to get good enough image quality.
Instead of that I now have an Opticron monocular, which naturally is slightly less than half the size and weight of equivalent binoculars, and the image quality and light gathering are excellent. The only thing that you miss out on is the stereo vision you can get with binoculars, but you have to balance that against resetting the inter-pupillary distance, which is always wrong when you pull them out of a case, and keeping the dioptre adjustment correct.
Two other advantages for me are that the monocular is only half the weight to hold to the eye and now, with a bit of practice, I can keep the second eye open and have an awareness of my unmagnified surroundings, similar to what photographers sometimes do.
You can generally pick up an Opticron 8x42 or 10x42 in the £150 to £200 range, if you can cope with a slightly less bright image they do an 8x35 cheaper (and lighter and more compact) and even smaller ones.
Jim
Jul 29, 2013
9,089
18,833
Salisbury
When I was looking for some they were a bit like hens teeth(y)(y)
Silas
120
114
Stafford
Kontiki
One month
Another vote for opticron here. Very well made and good value. You can get their 8x32 for about £80.00 and they are really good
icantremember
8,349
17,578
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Good quality binos well cared for will almost hold their original price.
My Leica Ultravid 8x42 are about 15 years old and apart from replacing lens caps they have been great and perform as well now as when new.... happy to recommend Leica.(y)
Feb 20, 2017
861
2,471
Kent
Bailey 75-2
Tugger now Motorhome
Canon Image Stabilising Binoculars - brilliant piece of kit - try them. With any binoculars the higher the magnification the harder they are to keep still unless tripod mounted.
2,481
10,856
Another vote for Opticron
Opticron Imagic 10x50 .. had them for over 20 years .. a bit big for walking perhaps, but excellent quality and clarity , with long eye relief and waterproof ..not a twitcher, I bought for general purpose and star gazing
review here http://www.skyatnightmagazine.com/review/binoculars/opticron-imagic-10x50
£170 from Wex
as for objective lens size, ?
.. much like engines.. there is no replacement for displacement ;)
12,270
45,087
Two wheel job towed.
I have Nikon Monarch 10 x 56 waterproof , not for the pocket but bright sharp image.
JeanLuc
3,304
2,199
Warwickshire
A few second hand high-end bins here https://www.cleyspy.co.uk/used-equipment.html bear in mind that the premium manufacturers tend to make incremental improvements to their models over the years without making a song and dance about a new launch, so an older pair may not perform as well as the most recent incarnation. CleySpy is an excellent dealer. We make a point of visiting north Norfolk if we need anything from them; also a great birding area of course.
P.s. I don’t have a pair of Swaros myself but would definitely go for them if changing. I use Zeiss Conquest HD 8x42 which are very good indeed; they are Zeiss’s mid-range and about £1,000 less than their Victory SF which is the alpha bin. I do have a Swaro scope and the quality of the image is outstanding.
Reactions: DBK
Feb 22, 2008
12,270
45,087
If you don’t already have one a Sony RX10 3 or 4 camera, incredible magnification, image quality and steady shot, look and snap, great camera.
Sorry a bit off thread but worth looking at .
DP+JAY
2,538
14,787
Dalbeattie
Laika 5009
Viking Badger 8x42, don't be put off by the sub £100 price tag.
BROKEN LINK
We wanted something decent but that wouldn't hurt too much if they were lost,stolen,or dropped by grandchildren etc.
Snowbird
11,818
22,347
Liverpool.
Fifth wheel.
Since 11-05-2000
I know absolutely nothing about binoculars, but I inherited a huge pair of Russian bins from my father and they are great apart from I need a caddy to carry them. I was given a modern pair of Penta, made in Japan by a friend which are much easier to carry, but they are not in the same class as the old Russian ones.
