Bessacarr E765 fresh water drain WHERE? (1 Viewer)
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Hello funsters, can any folks out there enlighten me as to where the fresh water drain valve is
Bessacarr E765. 2006 year.
Found a panel near step to washroom, not under there, found waste drain in rear offside locker but no fresh drain valve.
Must be one somewhere but I'm lost now, can see filler tube for fresh water, but that disappears thro floor, can't even see a fresh tank.
Stuart
Nov 7, 2009
235
758
Drain
If I have read your post correctly ,is there a lift up cover under the bed or seat ?
Lift it might reveal a screw lid . Remove lid is this the water tank? If so put your hand in you will find a rubber plug remove plug water runs out ,don't forget to replace it before filling like I have more than once . Hope this helps if not ignore .yours Dave
Gauntlet
78
78
Lanarkshire
Don't own one yet
I'm a newbie
I have a Bessie in mine there is a hatch on the floor just as you come in the door lift it and un screw the black lid and you then take out the bung
Autowbars
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Thanks for the quick replies, however nothing near door, only panel is near washroom and can't even see water tank from it so it must be between skins of look.
I will just have to run taps to empty and then empty waste tank.
Don't like that as it may cause damage to pump me thinks.
Stuart
Gauntlet
78
78
Lanarkshire
Don't own one yet
I'm a newbie
Stuart
Contact Swift or a dealer they will tell you
Autowbars
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Tried Swift yesterday, they say it depends on build date, order number, build framework, (whatever that is ) and a few other factors.
IE they have not a clue
