Battery charging hyma info (1 Viewer)
Apr 10, 2014
234
58
huddersfield
Fiat
newbie
Firstly I appologise if this is hidden somwhere but I can't find it ,can someone inform me as to if when ime plugged into mains electric after the leisure battery has charged dies it also charge the starter battery on my 1994 hyma b534 ?, the on board charger unit is the basic charger unit wushu no relays etc la 110 , thànks in advance
TheBig1
17,630
43,279
not on the early vans but it was a feature of later vans with the newer charger. to charge the van battery you need to select it as the source from the control panel whilst on charge. just a rocker switch on early vans
or you could fit a charge bypass relay or battery master or wire in a second battery trickle charger
43,329
49,446
no, an analogue/mechanical battery charger (which you have) cannot select individual batteries to charge from a bank or indeed individual batteries.
Multiple batteries in the same bank will charge at the same time.....but...more batteries, longer charge time.
