Battery chargers?
Discussion in 'The Beginner' started by Volusia, Oct 28, 2013.
  1. Volusia
    Volusia
    Oct 2, 2013
    206
    174
    Haute Vienne France
    Hi all. Can anyone recommend a good, reliable trickle charger for the leisure battery?
  2. superk
    superk Read Only Funster
    Aug 22, 2007
    503
    57
    Devon
    Always found CTEK good:
    CTEK chargers are the smartest car, marine, leisure and commercial vehicle battery chargers in the World. Designed and developed in Sweden, they are highly versatile, easy to use, compact battery chargers and proven award winners*. All the products manufactured by CTEK are tested and then constructed to the highest standards, which are far in excess of those required by the top product testing agencies such as the independent testing and certification agency, TÜV Rheinland Group.
    http://www.ctekchargers.co.uk/?gclid=CLeOzaa4uboCFbLLtAodpGcAVw
    Keith
  3. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,319
    8,026
    West Norfolk
    Firstly, a 'trickle charger' is a thing of the past. Continuously charging a battery at a fixed voltage is bad for the battery!
    I must presume that you wish to leave your an on hookup and maintain your battery.
    Have you identified the type of onboard charger that you have in the Rapido. Rapido have used CBE electrical components for a while now, you already might have a charger suitable for 'floating' your battery and maintaining its condition.
    If not, I know halfords and Ctek make chargers that you can connect and forget, allowing the charger to look after things.:thumb:
  4. Volusia
    Volusia
    Oct 2, 2013
    206
    174
    Haute Vienne France
    Thanks for the info, must look around to see if one is already fitted, if not its going to be as you both recommend. Thanks again.
    I used to have 5 leisure batteries on my last boat with a Clarke charger set on a timer of around 20 mins a day. Worked well but one you suggest sounds great.
  5. TheHat
    TheHat Funster Life Member
    Feb 26, 2012
    161
    127
    thurrock
