today I set to replace a parallel pair of 110 ah deep cycle batteries for a couple of Duracell units
On a 2006 Ellegance I821 ther batteries are under the floor area but are also open to the habitation area ,the cheap existing batteries are named as sealed maintenance free ,wrong,these babies were gassing and as hot to the touch,ther is a misnomer here,sealed and maintenance free is misleading,,should a cell (6 in a 12 volt unit ) short out due to deposits bridging the plates internally,then the sophisticated charger see,s a under voltage and steps up to replenish the charge,however the the pair would never self repair so the charger continues to pump in more amps ,thus this heats up the electrolyte and eventually the battery gives of a nasty smelling odor and if not corrected a potential explosion ,or more likely head aches and nausea of the occupants .
The batteries were not fitted with external vents to pipe to the outside these gasses,a requirement in a internal location,so don't assume a nasty smell is grey water odor ,check your battery often ,and when replacing them check the vents exist and clear of debri
