Battery Buildup
Discussion in 'Tech/Mech General' started by Ivys, Sep 28, 2011.
  1. Ivys
    Ivys Funster
    Sep 29, 2007
    215
    6
    Chieveley, UK
    Hi All
    Please see attached pic.
    Do I have a problem with my battery or something else?
    Am I overcharging?
    The battery is about four years old. It's one of four. No other batteries have buildup.
    [​IMG]
  2. runner2011
    runner2011 Read Only Funster
    Sep 28, 2011
    8
    Ireland
    Looks Nasty! Don't touch it with your hands as that is acid. You can remove the build up with Baking soda in water as that will neutralise the acid and clean off any remaining with a terminal brush. When clean put some vaseline on the terminals to prevent oxidation. you will need to clean the terminal leads and or replace if they are really bad. Of course there could be an underlying problem with the battery like a cracked case or burst cell ...but not always by any means. Hope this helps.
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,804
    6,065
    Mansfield,Notts
    Its quite a common ocurance
    Pour boiling water over the effected area, dry off and then apply some grease or vasaline to all the metal parts and battery post
    Geo
    • Like it Like it x 1
  4. scotjimland
    Jul 25, 2007
    28,941
    25,637
    I suspect it just needs a clean..
    remove the negative/earth battery connection first ,
    pour a mix of baking soda and warm water over the corrosion..
    once clean, remove the post connector and clean both the post and inside the clamp, you can either use a small wire brush or buy a specially shaped one from an auto shop..
    once clean, replace the clamp and smear all over with petroleum jelly.
    finally replace the negative
  5. motorhomelover
    motorhomelover
    Jul 28, 2010
    1,719
    613
    The world
    Looks bad but nothing to be worried about
    clean it and grease with jelly
  6. Ivys
    Ivys Funster
    Sep 29, 2007
    215
    6
    Chieveley, UK
    Thanks for all the replies folks.
    I must say this is the first time I've seen this sort of buildup on leisure batteries. I'm also concerned that it's only on one of the four batteries.
    I'll clean it off and see how it goes.
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,126
    17,793
    YO11 2BD
    I agree with the others regarding boiling water but DON'T clean the terminal with water if you're stood on concrete.
    my past experience is it will stain the concrete light brown and you cant get it off.
    could just be the quality of the concrete, but my aunt went mental when i did hers on her drive....and the stain is still there years later.
  8. Ivys
    Ivys Funster
    Sep 29, 2007
    215
    6
    Chieveley, UK
    Until I get the battery right out I can't use water anyway!
    ...it's a Euramobil with double floor.
    I may need to get a bowl of water in there real careful to dip the terminals in.
  9. pappajohn
    Aug 26, 2007
    30,126
    17,793
    YO11 2BD
    :Doh: i read the post and still had engine battery on my mind when i replied (very common on engine batteries)...same applies though, you have to stand it somewhere to give it a bath. :Laughing:
  10. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    It could be a faulty earth on that battery, I had that once on vintage car. Pete :thumb:
  11. Ivys
    Ivys Funster
    Sep 29, 2007
    215
    6
    Chieveley, UK
    But why would that only affect one out of four batteries?
  12. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    It is caused by a poor/dirty connection in the first place, so a good clean and coat in vasaline will cure it.
  13. Ivys
    Ivys Funster
    Sep 29, 2007
    215
    6
    Chieveley, UK
    When I got the battery out I discovered that the casing around the terminal was damaged. Probably happened when the batteries were last serviced.
    ...new battery me thinks
