Battery advice (Nooo not the normal thread!) (1 Viewer)
wingman
1,217
3,333
Romford, Essex
Coachbuilt Lo-Profile
Since 2012
I thought I had a maintainance-free leisure battery. WRONG!
Pulled it out today and found an unfamiliar (to me) battery.
I'm used to either a 'leave it alone till it dies' one (like on my car) OR one with screw caps where you top up above the plates. The one on the van is odd; well, certainly to me it is! It just has ONE 'hole' and a colour code next to it (See pic).
Having unscrewed the 'bung' it has a stem attached to it. Am I right in assuming that this is some sort of dipstick (just like me :D). The stem is white. Do I further assume that I need to add distilled water - pronto!
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
It says on the label, white- add distiller water, I assume this refers to the dipstick unless there is a little window somewhere.
Allan
andy63
4,672
15,017
south shields
None
since 1990
hi wingman I had two ussa batteries with a similar set up for a while.
the removable plug allows you to add distilled water and also serves as a state of charge indicator..
if I remember correctly mine had a small green ball that floated in a tube.. looking down on the plug from directly above you would hope to see a green colour... anything else would indicate you need to add water or the battery is flat.
ta andy
wingman
wingman
1,217
3,333
Romford, Essex
Since 2012
Thanks Guys.
Battery isn't flat Andy. Should be thirsty though :D.
When I didn't see a line of screw-tops, I just assumed it was a gel type and maintainance free. Every day a discovery eh?
Feb 24, 2013
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
I suspect you will need to pull the battery out of the housing to check the colour coding, you will probably need to be directly above it see, not the best of designs for most MH battery locations
Thank goodness I have gel batteries :D
andy63
4,672
15,017
south shields
None
since 1990
just check that it is green after topping up... suspect it will need a good charge...
ta andy
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
Just re-read your OP, I now think the stem could be the vent, which should have a pipe attached to it going out of MH
DBK
18,025
48,095
Plympton, Devon
PVC, Murvi Morocco
My guess is you have an AGM battery which was shipped dry. The "vent" was used to fill it after installation. It should not require any maintenance.
scotjimland
2,334
10,098
A Woosh bang
Details of your battery here
http://www.yuasa.co.uk/batteries/leisure-marine-garden-view-all/l36-100-l36-100.html
Features
  • Caravan/leisure use
  • Long storage life
  • Deep cycle
  • State of Charge Indicator (SOCI)
  • Enhanced safety venting
  • Integrated flame arrestor
It is a flooded lead acid.. the vent on the end is used if the battery is housed inside the van to vent gasses via a tube to the outside world.. If housed in a vented dedicated outside locker it is not required ..
There are downloadable Battery Care and testing guides here from Yuasa
http://www.yuasa.co.uk/info/downloads/battery-care-testing/
wingman
wingman
1,217
3,333
Romford, Essex
Since 2012
Thanks for all the replies lads. Apologies ....... I've been off-line. @PJGWiltshire I've sent you a PM.
I have had a problem with my internet (my land line has been down, then up, then down again!) Am currently using a 3mobile Mi-Fi gizmo as a stop-gap that I normally use in the van whilst Open Reach decide whether to repair it, or make me wait!
Have topped it up, put it on charge, all appears ok.
Regards
James
1,588
2,281
Lancaster
None
Since June 2008
I have a different set of indicators on my battery.
wingman
wingman
1,217
3,333
Romford, Essex
Since 2012
Yes, @steelysteph. I've got those too, but they are the standard warning icons. I was talking about the green/ white and '0' indicator key by the side of the filler plug (n)
