batteries (1 Viewer)
ukbill
5,501
5,274
Pinoso
4 berth low profile
If i join my 2 leisure batteries into a 24v connection (+to- etc) will this damage my charger to the batteries ?
11,934
9,104
Without knowing what charger you have -I would assume you have a 12v charger so yes it could kill the charger and or damage your vans electrics -or simply shut the charger down/blow a fuse --If you must have 24v then disconnect the charger/check your chargers output or buy another that does duel voltage
terry
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
thx terry thats that problem solved and another grand plan of mine out the window :)
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
i assume that now i have 2 batts instead of 1 the charger will still be ok ?
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
i bought by mistake a 24v to 240 500w inverter so was gonna try it lol
11,934
9,104
Yes Bill two batts connect + to + will be seen as one bigger battery -Depending on the size of your charger it will take a bit longer to reach full (y)-A small charger may struggle to charge batts to full capacity-as a rule of thumb you need aprox 1 amp hr to every 10 amps of batt size == a 12 amp hr charger will charge 120 amp battery -but since you only go down to 50% discharge =240 amphr worth of batts
terry
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
thx again terry i will check my battery charger the batts are both 110am i am now also looking at a solar panel of around 80amp just a project for me to do bloody bored i suppose :):)
11,934
9,104
The charger size is just a guide Bill (y) for optimum performance --even small chargers may keep your batts charged simply because they keep banging in charge -some small intelligent chargers may baulk at bigger battery banks while others just get on with it :) a case of suck it and see -
I am coming around on Solar panels -mainly because the wife is not around to stop me - but they are reasonably cheap now and would cut the need for me to hook up at home (always have done)but find myself hooking one van up and forgetting the other only to find the alarms etc are flattening the batteries on the none hooked up van --always been against Solar as I have never needed it but now it's only a hundred quid ish I may have to look into it more closely :D or I may PM Tecno and save myself the bother (just pick his brains on the subject):D:LOL:
terry
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
it was techno who guided me terry i am going to get the relay he recommended and have the inverter straight into the mains so when not on hookup my sockets will still be live @240v the 80amp solar is around 70quid but dont forget all the other bits to go with it fixing brackets charge controller cable etc so far i think im at about 130quid still very good i reckon
18,040
48,160
You can get 12v to 24v DC convertors, but they are not cheap and I doubt anything affordable could handle the current required by an inverter. Here is a small one: Broken Link Removed
11,934
9,104
ÂŁ130 ISH WAS MY THINKING - OR ÂŁ150 FOR 100W PANEL --Who knows I may get around to buying one for my own next build :D
terry
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
dont forget terry that quote was for everything not just the panel but dont include the relay i need to connect to the mains i will keep you posted of the outcome when i have done it all but if u dont hear from me for a while watch the news for the blast i will cause lol
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
is that a solar controller peter
Aug 30, 2012
4,270
11,305
Home of the war horse
burstnar T640
Yes I had it removed for a 30 amp when increased panels from 100 to 280 watt in Morocco last winter if you want it we are only in Leeds so if passing pick it up or I will post it free to you mate
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
i will have a 80w panel will it be ok for that ?
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
i can swap it for a 24v to 240 inverter if u want it lol
11,934
9,104
Hi terry
I have a 10amp controller going spare if you want it ?
Thanks :) but as yet I have no idea if it would be any good for me (y) or if it would sit in my garage gathering dust -I need to do some homework on Solar (or simply pick others brains:D) to see if I need rather than want it -I have Ann nagging in my head as I type :LOL: there are a few things I want in my own build rather than need ;)I have some nice goodies to put in and all the stuff except the fridge and loo plus windows so after buying the van it will not cost that much :D
terry
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
terry the reason i am going now for solar and a inverter is because i am fed up with having to start the genny everytime linda wants to use her straighteners and its no good me explaining to her why the sockets dont work wen not on ehu so i is cheaper to put this stuff in that explaining lol
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
its ok jj i have a 1500w on its way to me but anyone who wants the 24v 1 can have it it didnt cost me much and the fact the seller gave me over half me cash back i would say it stands me in at about 5quid of free to anyone who wants it
Jul 5, 2013
11,732
13,714
Bill
Was that the same inverter we were discussing on another thread? Sorry it did not work out for you.
I think you want to get as much solar power as you can. They are very cheap and you can often find larger ones are not much more expensive. I got two 100W panels plus additional 10m of cable and two joiners for ÂŁ190 from memory. And since you are up on the roof anyway and having to drill a hole in the roof you may as well fit two
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
no peter that ain't the inverter from the pother thread this 1 i bought ages ago not looking at its discription proper to see it was a 24v lol i reckon tops 100w will be plenty for me i will visit a solar place next week and look what they have
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
I am glad you have solved the problem of having to explain why the sockets don't work to your wife.
You will now have more time to your self.
Unless of course you spend it explaining why the batteries are flat;)
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
hope fully the solar will sort the flat batteries out and i doubt the inverter will be usaed that often anyway
ukbill
ukbill
5,501
5,274
Pinoso
4 berth low profile
yes peter i will have it mate can u post it im down south so bit of a drive for me ?
gibbon
307
325
Shatterford
My other half uses 12v hair straighteners & she reckons they're as good as her mains ones, cost ÂŁ11(y)
