Batteries off grid - my findings - my fix (1 Viewer)
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
Morning, I thought I would give my batteries a good "bashing" whilst in the UK for 3 weeks and would like to share with members on here my findings as I have read all the posts on here about "my battery is dead" or "why is my onboard charger not changing my battery" or "why does my engine not charge my batteries whilst running parked up"
Firstly I have the following:
(a) 3 x 110amp hour battery - These are in good condition and hold charge well.
(b) Victron BMV 600S - This is by far the best thing for monitoring your 12 volt system.
(c ) CBE charging system as fitted by MH manufacture - After many hours of searching the CBE system I have 2 x Safety relays EPC they are both in front of the CBE box.
Photo:
The inside of the case with the relay, fuse 50Amp (power circuit) and one 5 Amp. (Control circuit relay)
(c) Solar panel 80watts - A 80 Watt solar panel will give you about 320 Watt-hours of energy on a summer day. For a 12 volt system, that corresponds to 26.7 Amp-hours put back into your battery bank each day. On sunny days, you will get more; on overcast days you will get less. So in Winter, your 80 Watt solar panel will only be giving you about 80 Watt-hours of energy per day in the worst case. For a 12 volt battery, that corresponds to 6.7 Amp-hours put back into your battery bank each day .
(d) Ctek MXS 25 main charger - This runs off mains supply (EHU) or gene ( no problems with 10i ) It will start off charging at 14.6 and drop down over a period to 13.5 - start up can be 16/18amps then down to 0.1 amps depending on how long you run the gene for. I have found that after 2/3 hours the batteries are charged with NO load on the batteries.
(e) Honda 10i Generator - This was bought after being recommended by many people as being the best out there. To date I have used it a handful of times, however over the past week it has been on most nights for this test.
Findings:
A typical night parked up we would have a few LED lights on the TV and Sat system with tuner box. At most about 4.5amps for 4/5 hours and as and when the water pump ( for cuppa etc ) so quick 3/4 amps. The batteries lasted first night no problem and the second, however by the third night voltage is around the 12.4 mark, that is without moving or charging. During the day here in the UK the solar panel is at best just taking up room on the roof. So happy enough I thought the batteries and charging system were doing what they should.
Now as many on here think - no problem, I will start the engine and that will charge the batteries whilst I'm parked up....... NOT so as such because it takes hours of engine running just to add a few amps. A battery needs about 120% INPUT to get to full charge...so...your 110 leisure battery/batteries would need: 110 x 120% = 130Amps per hour. I have 3 x 100!!! Normal charging rate is at 10% for best life...SO.....13A for 10 hours and as most alternators will charge....14.2 - 14.4V at about 2000rpm it will drop the amps from 5/6/7/8 at start to 0.2 after 1 or 2 hours of running. So after that you are only trickle charging so that when you park up the batteries look good for about 1 or 2 hours and then the voltage drops very quickly. At this point many think that their batteries are destroyed because they wrongly or rightly think the run/drive should have charged/them.............
So running a gene would resolve the problem....... well sort of.... the gene can only put in xxx amps so the same effect happens unless you're running it for hours on end ( not recommended in a busy location - at best you will annoy people off at worst it will get stolen! ) so I thought why not try a........
CTEK MXS 25 Mains charger which would work whilst on EHU and for use on the generator. Well it works great on EHU conditioning the batteries and can on the generator charge the batteries in 1/2 hours ( with NO LOAD ) pushing into the batteries 14/16/18 amps depending on state of charge, however again the generator has to be run. Please note I do not use the word "fully" as the following conditions apply: 2 hours at 10A = 20 - 5 hours at 5A = 25 - 10 hours at 3A = 30 and 20 hours at 1A = 20 (The last one is your engine running! )
So now what next.......... Well if you're never "off grid" you have nothing to worry about. If you are "off grid" once in a blue moon again you have nothing to worry about as in both cases your on board charger will sort things out for you as soon as you return to EHU.
If however you plan to use your MH without paying for the privilege of EHU then I hope the above helps you understand that in the case of 12 volt you need more than the standard charging system fitted to most motorhomes.
Keeping your batteries charged off grid is a bit of a black art and as many do not fully understand the charging system that they have fitted in the motorhome I thought my findings might be of use to others ( don't forget the like button )
I have ordered a sterling battery to battery charger and hope to fit it before leaving the UK to head back home to Spain, but I'm not too worried if I don't. My plan is to get rid of the gene as carrying it means carrying petrol too.
I will update this post when I have had the sterling battery to battery charger fitted and tested.
Any feedback on the sterling battery to battery charger from those who have fitted it would be great and even better if you have fitted it with a CBE system.
Thanks for reading.
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Wow. What a great post. Think I might need to re read it several times before I fully understand it. Thanks for taking good the time to write it and look forward to your update.
There is no thanks button anymore.
THANK YOU.
Don Quixote
Don Quixote
2,966
5,258
VW T6 Campervan
THANK YOU.
Changed the thanks to like, ta. It is such a "gray" area I thought many would like to at least have an understanding about their charging system. Thank you.
Jim
Ringleader
Jul 19, 2007
36,417
130,897
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Since installing the Sterling Battery to Battery charger, along with a , I have not had cause to run our Honda Generator at all. This year at some rallies the Funster band have been using power straight from our two 110 Banner batteries through the inverter. Should the band get too many encores (a common occurrence) I know all I have to do is run my engine a little while and the batteries are back to 85/90% very quickly (y) Who needs a genny, who needs the sun. You just need a B2B- for me its perfect.
Nov 6, 2013
3,201
229,477
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
Great post John. Thanks for taking the time to let us know your findings. We are going to change our van soon and hope to have solar/inverter and b2b fitted so we can do more wild camping (y)
John
Don Quixote
Don Quixote
2,966
5,258
VW T6 Campervan
John
Well I would not have a solar panel fitted ( unless going sunny places a lot ) if you're going to have the sterling battery to battery charger fitted as it will do everything you require and you will not be adding weight that you do not need. The inverter on the other hand is a must for the wife hairdryer............
Don Quixote
Don Quixote
2,966
5,258
VW T6 Campervan
Hi, my experience of a Sterling A-B charger can be found here-
Broken Link Removed
Very interesting read on your fitting a Sterling 160amp Alternator to Battery Charger. I have gone for the 12-12V Battery-battery 50A digital charger because I liked the "simple" fitting area, however your post has answered my question about transit fitting and no vehicle mods at all, so it should work fine with my CBE charging system. I can I think if needs be remove the CBE charging system by removing the fuse from the charging system as shown above.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Does your Transit have the single or twin battery configuration?
This will determine how your leisure batteries and CBE electrical system is wired in.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
You will need to fit an isolating relay to your leisure battery bank in order to ensure your B to B will charge correctly.
You can't just simply remove the split charge fuse because your fridge and habitation electrics will draw from the B to B too, reducing its charging current to the leisure batteries.
Simply put a 70 amp five pin relay between your leisure batteries and the CBE panel B2 terminal. Use an ingn or D+ feed to the coil and use the normally closed contacts to connect the batteries.
When the engine runs, your leisure batteries will be connected solely to the B2B charger. Meanwhile, the original split charge relay will supply all your habitation electrics and fridge.
Don Quixote
Don Quixote
2,966
5,258
VW T6 Campervan
Jon now
You have me thinking.... as there are so many CBE systems my understand is that the one fitted by the Benimar / Chausson has 2 x Safety relays fitted. I have not looked to much into them yet, but my understand is one is for the battery (a) vehicle battery (b) leisure battery. Therefore as long as I connect to vehicle battery to the sterling changer it should be fine, but this is new to me so at this stage more reading is needed. Thank you for the help.
GJH
29,450
38,827
None, now sold
2006 to 2022
Very interesting and my thanks as well. I was particularly interested in the solar panel figures:
We have a 80W panel and 80Ah battery which we find adequate year round but I had never worked out the figures. We don't have a TV or satellite system and the fan for the blown air heating is pretty efficient so it would be unusual for us to use more than about 6 or 7 Ah in a day.
Don Quixote
Don Quixote
2,966
5,258
VW T6 Campervan
Graham, you don't say which blown air system you use. We have the Webasto Diesel system and when that boots up it can draw 7/9 amps whilst it sorts itself out and then drop down to 1 or 2amps blowing around the MH and then draws 7/9 amps to shut down. In Spain we never use it, but over the past few days it's been working away. Even if you're only using 6 or 7 amps a day that means you need 18 to 21 amps back to fully charge your battery not just top it up. This is the problem as many think..... the solar panel is working and fully charging the battery. It is not and over time the battery needs a full charge to make it work correctly or die. Hence my post so people can understand that in many cases the charging system fitted is not up to the job. Many go in EHU and park up for 2/3 days and this is where it does the job as it takes 2/3 days to fully charge battery/batteries.
Jan 24, 2010
2,440
4,848
Adria Twin
Jon now
We have exactley the same set up in our chausson, when I fitted our b2b I looked at the extra relay fit from jon, but after much tinkering found it wasnt needed as the two security relays did the same job, and it works well.
Don Quixote
Don Quixote
2,966
5,258
VW T6 Campervan
Ah....... perfect may I ask then did you just fit it and forget. Did the security relays work in that one or both could see the charge coming in and stopped/reduced the charge from the CBE unit. It should arrive tomorrow, but need to get cables as well looking at 25 mm sq from to battery. Thanks for the info.
GJH
29,450
38,827
None, now sold
2006 to 2022
Graham, you don't say which blown air system you use. (snip)
It's the Trumatic C3402 John. Takes a couple of amps for a short while when starting then virtually nothing. The van is pretty well insulated so we don't need to use a lot of heating.
All the electrics are through an Elektroblock EBL99 (solar panel wired direct into it) so no need for any other B2B arrangement.
Jan 24, 2010
2,440
4,848
Adria Twin
I did have issues with the extra relay fitted, control panel and fridge were throwing intermittent wobblies. But since removing it all is well.
Having pawed over the wiring diagram for the van for hours and doing testing with a digi meter I found that the 2 relays did a similar job, and each was specific to either the cab or hab bat
In ours s1 controls the charge from the cbe charger on 240v to the cab battery, once the hab is full and s2 controls the charge to the hab battery from the alternator via the cbe, both voltage sensing. So on the move s2 only opens when the cab batty is fully charged and the hab bat is below a certain voltage (not sure what though!!) All other 12v wizardry on the move such as the fridge is controlled by the main cbe charger panel (quite a good piece of kit.. and whilst im not 100% sure it may even act as a solar controller too!!)
Only snag I had was the cab and hb bats being at opposite ends of the van!!. I opted for putting the b2b as close to the cab bat as possible and using a hefty 800amp lorry jump lead to wire up to the hab bat at the rear.
Only taken an hour to get hab bats from 70% to fully charged today on a run back from a weekend away.
So yeah...fit and forget:)
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Not mentioned as far as remember is the need for more than 80W on the roof. I've been off-grid in the Midlands for 12 days so far and my batteries are fully charged by the end of the afternoon each day. I have 3 x 110Ah batteries and 230W on the roof. I use an MPPT solar regulator in conjunction with the Hymer charger. The Hymer charger allows any charging source to keep the starter battery ready for use and contains elements of B2B charging when the van is being driven. So far it all works well. My laptop use is fairly heavy although we don't use the TV much (around two hours in 12 days so far). All interior lights are LED.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
A very interesting thread. What I dont understand is this. On all the vans I have owned in the last few years I have had 330 amp battery banks with around 300 watts of solar. I have used the vans for periods of up to 3 months without hookup, and have never had a problem with flat batteries. The van I am running at the moment has a 330 amp battery bank with 250 watts of solar. It does have 2 alternators fitted to the engine as the engine is 24 volt. The 12 volt alternator is just for the habitation side so I presume this works much the same as a B2B, but am not sure. I do have a type of battery fuel gauge fitted which tells me the battery voltage, amps left, amps drawn etc and the 330 amps have never fell below 220 even after a few days without much sun. All 12 volt wiring is through a shunt, so I can tell immediately what is going in and out and also what is left. I dont see how I can improve on this system, but am open to suggestions.
Ivory55
6,017
14,534
North West Norfolk
Since Feb 2012
Am following this as it's interesting. One thing I have always wondered, on trucks I drive they hang a battery pack on the chassis behind the cab out in the open. Why do they not have similar on motorhomes . They make beany boxes to use space under the vans, why not have a cage for battery's under the van instead of sticking a battery under the drivers seat etc.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Batteries are happiest at room temperature and loose loads of capacity when cold.
You wouldn't want them outside the van in the Alps during winter.
They'd be OK outside for normal UK use though.
tambo
874
639
Dunfermline fife scotland
a class
MH Since 2008, ex tugger and vw campers since 1992
I have to ask what are you guys all running in these vans that you need all that power?
I've one 110 amp leisure battery ( I think it's 110 I've never actually checked)
I only ever use interior lights , water pump and a 15 inch 12v tv dvd combination.
I've no inverter no solar panels etc yet never had a flat leisure battery , never used the EHU or the redundant generator im thinking of selling, and I wild camp 95% of the time
Just curiosity
tambo
874
639
a class
That's where mine is , in a cage under the van
Ivory55
6,017
14,534
North West Norfolk
Since Feb 2012
How much loss would it be, no idea about truck battery's only it starts up every morning so must not lose to much. I know it's 24v on a truck that's my limit, ha ha
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Just curiosity
2 showers per day. 12 volt charger for laptop, phones, camera etc. 12 volt satellite and TV. Inverter to charge 2 scooters. Lights. Eberspacher diesel heater. Alde heating pump. Radio. CD player. Awning light at night. PIR awning light when am in bed. Macerator. Extractor fans. LPG inline heater in winter to stop gas freezing. AES fridge. It soon adds up.
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Last time I was on hook-up was 15 June. Since then I've been reliant (and in the UK) on my 3 x 110Ah batteries and 170w solar with MPPT controller (no fancy chargers or monitors). Has kept up with my usage no problem and I expect it to do so until October. I don't have a TV but use my laptop quite a bit (probably similar wattage). Every other day I use the inverter to run my hairdrier (albeit for only about 5 mins). Items like phone, mifi, etc get charged off the 12v as well. Water pump, water heater (on gas obviously but uses 12v for fans), LED lights as normal with most folk. I haven't used the heating because the van is well-insulated enough not to need it in August! Although being a soft southerner I run my electric blanket off the inverter if it's a chilly evening (80w for about 20 mins). Most days batteries are full again by early afternoon. Today they won't be because of wall-to-wall rain although solar is still registering 13.0 v even as it pours down. If we have four days or more of continuous rain, I'll run the 1KW generator on one tank of petrol until it runs out (about 4-5 hours). That is enough to bring the batteries back up to full charge.
Engine battery sits without charging quite happily for at least 3 weeks (that's the longest I've ever stayed in one place without moving). It runs the Strikeback alarm but I remove the radio panel to stop that drawing down.
So where am I going wrong?! :wink:
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
About 1% for every degree below 20 degrees C!
For instance, at -20, a 100 Ah leisure battery will only have a useable capacity of 30 Ah, assuming a 50% maximum discharge.
For a 100 Ah traction monobloc, you'd have 48 Ah of useable capacity left.
Our batteries are staying inside!!
Don Quixote
Don Quixote
2,966
5,258
VW T6 Campervan
The big difference is you have 230 watt solar panel, which will make a huge difference. I not sure that it will 100% charge, but cannot be that far off.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Just curiosity
In winter, 24/7 diesel blown heating, TV, satellite system, lights, charging phones and laptop, hairdryer, for 2 days at -5 to -20 or less!
We recharge every other day.
In the summer, those batteries save gas by boiling the kettle!
