Bathroom mirror removal (1 Viewer)
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
the bathroom mirror is past it's best, knackered round the edges and a few marks so want to replace it. No problem to source a piece of mirror, but getting the old one off is proving more difficult !
It's large, and is frameless, and is stuck or glued to the wall.
Have tried running a hacksaw blade behind it, the blade broke!!!
Short of taping it up and using a hammer, any bright ideas???
Lenny HB
53,448
150,056
On the coast in West Sussex
Hymer B678 DL
Don't remove it you will do a lot of damage. Fit the new mirror over the top.
Our current van one of the mirrors had a tiny bit of the mirroring going at the top hardly noticeable, we had it replaced under warranty, Hymer told the dealer doing the work not to remove the old mirror just fit the new one over the top. They fit them using an extremely powerful double sided adhesive tape.
Nov 4, 2011
5,941
38,967
Uk
That sounds a good idea, as we have the same problem, do you know what they stuck the new one on with.
Lenny HB
53,448
150,056
Hymer B678 DL
Sorry don't know what they used, might be worth asking a local glass company that supplies mirrors, or you could use a PU adhesive like Stikaflex.
BreweryDave
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
Did consider that, thought the weight of glass on top of more glass may not be a good idea, and also would it bond???
Riverbankannie
10,535
61,563
Bristol
IH 630 RL PVC
I have removed mirrors, stuck to a plaster interior wall, with fine wire from a roll of electrical stuff. You need a piece long enough to go around the width of the mirror and to hold each side. As you slice it down, it cuts through the centre of the sticky pads leaving a part on the wall and a part on the mirror so no damage was done.
Nov 4, 2011
5,941
38,967
Uk
Hi BreweryDave
Did you sort your mirror and if so how did you do it in the end.
BreweryDave
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
Hi BreweryDave
I did. Decided against removal, tried gently but it wasn't going to happen!!!
Simply had another piece cut to size and stuck over the top of the old one with some mirror specific mastic stuff, worked a treat and looks great!
