Bathroom door hinges (1 Viewer)
reenag06
70
14
cheshire
Autocruise starspirit
I'm a newbie
The bathroom door hinge screws have come loose and they need replacing. Does anyone know how to make them more secure as there is very little thickness to the panel they screw into without them coming through to the inside of the bathroom.
Maureen
SandJ
1,799
818
North Yorks
Too long lol
Fill hole with wood, mat stick, wooden barbecue scewer. With or without wood glue and tighten but not overtight.
Reactions: GJH
pops
544
697
south glos
Pilote panel van
since1997
I always carry a box of cocktail sticks and break them to size to fill in hole and then lightly tighten screws.
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
Perfect timing. I have the same problem..Will try matchsticks. Silly question.. light them and put them out or cut the ends off?
17,635
43,369
put a dab of araldite n the hole and put screw in but not overtight. allow araldite to cure before using the door
once set, the araldite, screw and wood are fused together
MattR
4,105
38,998
Beds
Panel van
Years
I wouldn't want to have it that permanent; maybe add araldite or pva glue to the hole & matchstick but allow to dry before screwing in - you never know when you may need to dismantle things in the future.
17,635
43,369
you can unscrew them later if needed but they take a little moving
westy77
247
180
Is it possible to nut and bolt with washers or a nice tidy plate through the wood? If you have access to both sides that is.
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
(y)(y)
A rawlplug. That's what they're for, fixings in materials that crumble.
Rawlpugs are generally used for brick/masonary, probably find the board being screwed into is only 18mm max maybe less, therefore unsuitable for a rawlplug
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
(y)(y)
Get some that are the right length, or, cut them to length. That's what I do. It's all that people using match sticks are doing.
reenag06
reenag06
70
14
cheshire
I'm a newbie
Thanks for all your suggestions. Think will try the rawlplugs - have seen some called plasplugs for hollow wood doors so they may be ok. Yes problem is that the board to screw into is hollow and narrow so not sure about matchsticks as they may just fall into the hollow bit. Will give it a go and let you know which solution works. This forum really is a gem for pooling knowledge and ideas. Thanks.
MattR
4,105
38,998
Beds
Panel van
Years
Can you post a picture of the door and hinge area? I would be surprised if the door was hollow where the hinge is.
reenag06
reenag06
70
14
cheshire
I'm a newbie
Here are photos. Sounds hollow though.
2,347
10,194
If the screws only have a thin ply to go into, this problem will only recur..
I'd be looking at fitting a full length brass piano type hinge ..
reenag06
reenag06
70
14
cheshire
I'm a newbie
Thanks, have had a look and they could be a better solution.
Will keep you updated...
musson
487
165
grantham
low profile
since Jan 2014
Hi could you drill the holes bigger (make sure you dont go through) then glue some dowel rod in with areldite
then refit with orginial screws that way you can always remove the door if needed
reenag06
reenag06
70
14
cheshire
I'm a newbie
Am going to spend time today to try and sort it. Will keep you posted. (y)
reenag06
reenag06
70
14
cheshire
I'm a newbie
Have filled holes with wire wool and the screws have gripped the wire wool and they feel tight at the moment so will see how it goes. If they go again will get full length piano hinge. Thanks everyone for your suggestions, as always so helpful.
17,635
43,369
sorry to burst your bubble, but wire wool will rust because of the steam in the bathroom and cause problems like rust and stain marks
reenag06
reenag06
70
14
cheshire
I'm a newbie
Am hoping this won't happen as the holes are on the outside and there are no holes on inside. Also haven't used bathroom as shower ony use toilet and sink but thanks and will keep an eye on it.
It's good to get the for's and against's.
Maureen
SandJ
1,799
818
North Yorks
Too long lol
From pics it looks like you can drill right through the wall. If this is the case then do it and fit bolts with washers or a plate with holes drilled.
You can get countersunk bolts and spring washers for hinge side.
