Bargain G4 LED's on amazon. (1 Viewer)
43,337
49,538
[ame="http://www.amazon.co.uk/gp/product/B00662OUSO/ref=s9_simh_se_p79_d12_g79_i1?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=auto-no-results-center-1&pf_rd_r=39822330772F4BEAA103&pf_rd_t=301&pf_rd_p=240112507&pf_rd_i=Camco%2011563%20RV%20Aluminum%20Anode%20Rod%20Fits%20Suburban%20Heaters"]http://www.amazon.co.uk/gp/product/B00662OUSO/ref=s9_simh_se_p79_d12_g79_i1?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=auto-no-results-center-1&pf_rd_r=39822330772F4BEAA103&pf_rd_t=301&pf_rd_p=240112507&pf_rd_i=Camco%2011563%20RV%20Aluminum%20Anode%20Rod%20Fits%20Suburban%20Heaters[/ame]
11,843
14,080
Deffo a bargain but just have to watch out if they are actually 12v they might fail if voltage is up to 14.4v on charge. The more expensive ones I got from Aten are rated at 8v-30v with some sort of built-in stabiliser.
S
stagman
I wouldn't worry too much these are £2 each , and probabally from the same factory in China .:thumb:
jonandshell
5,476
8,299
Not got one!
We got 10 warm white LED G4s for £17.99 incl delivery on Ebay!
Used 9 around the MH.
They all work OK!:thumb: Even when running!
-We made an offer!:Smile:
43,337
49,538
Cheaper here
Specifications:-
Base: G4
LED Chip: 1210
Light Color: Warm White (3000~3300K)
Input: DC 12V
Power:0.9W
Lumen: 140 Lm
Life time: about 30,000 hours
Angle:160
Need led light special transformer
probably no LED driver circuitry inbuilt
jonandshell
5,476
8,299
Not got one!
Specifications:-
Base: G4
LED Chip: 1210
Input: DC 12V
Power:0.9W
Lumen: 140 Lm
Angle:160
I wouldn't say so, that probably is for the benefit of people who would try and run them on 230V at home!
Besides, no such thing as LED Driver Circuitry. Some, I know have a rectifier to solve incorrect light fitting polarity, but if you fit one and it doesn't go, just reverse the wiring!
Don't forget, an LED is a Light Emitting DIODE. A diode will only conduct current in one direction. You will only blow it up if you apply too much voltage in either direction.
