Awning Rail, Underneath Wind Out Awning??? (1 Viewer)
Teasy2007
2,086
1,159
Rotherham South Yorkshire
Carthago Malibu PVC
Hi, we want to fit an awning rail below, or onto the wind out awning.
Has anyone ever done something similar, or can give information/advice please?
Ginny
philw111
629
557
Moray Firth
Bessacarr 484
Since 2004
Our windout awning incorporates a channel that we use to attach our driveaway awning - yours could well be the same. You just need to get a connecting strip and the job's a good un (y)
Bartyfixedit
330
566
Maidstone Kent
Self Build Ducato L4H3
Since 1987
I have an awning rail on the side of the van, below the wind out awning. The drive away awning fits better on there as it isn't attached away from the van as when on the wind out.
I'll post a pic later.
Teasy2007
Teasy2007
2,086
1,159
Carthago Malibu PVC
Yes, that's just what we need, but we don't know which rail to buy, whether to screw or glue, or both.
Any info gratefully received.
Brisey
Sep 4, 2007
8,087
17,512
Sutton on Sea
Since 2003
Hi Ginny, we have a strip of awning rail above our wind out awning.
It is bonded to the van with Sikaflex, we didn't want to use screws.
Brisey.
Teasy2007
Teasy2007
2,086
1,159
Carthago Malibu PVC
We have tried the figure of eight strip and the Kampa Air awning just pulled out of the strip in the wind. We found the awning much too heavy for us to put up on our own, so we sold it in Spain.
We bought a second hand Isabella Minor with carbon poles which is very light and strong, but of course we need an extra awning rail.
The problem is which rail to buy, whether to stick or screw it to the motorhome or to the existing wind out awning, we need to get it right 'first time'!!!
Ginny
Brisey
Sep 4, 2007
8,087
17,512
Sutton on Sea
Since 2003
I was fortunate to be given a length of aluminum rail by Jim.
Perhaps he can advise you as to where you can purchase it.
Brisey.
DBK
18,045
48,204
Plympton, Devon
PVC, Murvi Morocco
Too late now but I think there are two different sizes of groove, 6mm and 8mm if I remember correctly. It is possible you had 6mm male bit, so to speak, in an 8mm groove.
Probably best not to dwell on that image too long as it wouldn't have helped the weight issue!
Bartyfixedit
330
566
Maidstone Kent
Since 1987
There you go. Standard awning rail that I got from Magnums motorhomes. Stuck on with Everbuild Stixall with a few small self tappers to hold it in position until the glue had set. DSC_0009.JPG
Teasy2007
Teasy2007
2,086
1,159
Carthago Malibu PVC
There you go. Standard awning rail that I got from Magnums motorhomes. Stuck on with Everbuild Stixall with a few small self tappers to hold it in position until the glue had set.View attachment 62261
Hi, thanks for the photo.
It's difficult to see which rail you have used, does it have screw holes above and below the rail, or is it the one with aluminium above the rail only. We looked at the slimline rail which is just the rail with no support either above or below, but this looked a bit flimsy and we were worried it might come away in the Spanish winter winds.
Ginny
Feb 24, 2013
13,109
101,579
Bolsover, Derbyshire
Hymer S800
not long enough
Have you thought how you are going to reach it? Our wind out awning is much too high for me to reach and I am over 6'
We have a Kampa Air and you are right it is heavy, but the advantage of using the wind out to attach to is it come down close enough to reach!!
TheBig1
17,645
43,461
the 2 usual types of awning rail are P profile and C profile
P profile is best as it can be bonded to a flat surface
as for beading pulling from the track, beads are either 6mm or 4 mm and you need the correct kador strip kit to connect
Teasy2007
Teasy2007
2,086
1,159
Carthago Malibu PVC
We have a set of steps which allow us to reach the rail, which will be 2.4 metres approx high. Once in the rail it should be easy to pull it the length of the rail, especially as the awning is quite light.
Ginny
Apr 11, 2015
5,427
55,552
hull
Laika Ecovip 300
Our new to us van has an awning track under the canopy, please dont use unsealed screws unless you want a damp van :-(
