Avtex TV (1 Viewer)
Dec 2, 2010
1,060
2,321
Hollywood, Birmingham.
A Class Laika
Since 2011
Why is my Avtex tv only playing sound and displaying "invalid picture format" here in Sligo, Ireland? The info screen displays MHEG5 when selected. All other functions ok including satellite tuner. Avtex model 18DRS/L215DRS. The set up menu interestingly does not include the Irish Republic in the country list.
M
Madwife
It probably is because Ireland now is all digital and the signal may be different. The Irish version of freeview is called saoirview and I presume you can tune in via your aerial. We haven't tried to pick up TV signal via aerial as just use the satellite dish and have very good pick up here in South Kerry
Kath
43,331
49,462
you may need to manually reset the signal mode to AUTO or PAL I and rescan....though that is the same format as the UK.
quickweh
Dec 2, 2010
1,060
2,321
A Class Laika
Since 2011
Solved!
If you need TV in southern Ireland you will need an Irish set top box for Irish programmes or a satellite set up. See below for explanation.
" Republic of Ireland Digital TV Switch Over
In October 2012 the R.O.I. turned off Analogue Terrestrial TV Broadcasts and therefore now only have a Digital TV service. The Broadcast Standard chosen by the Irish Authorities is different to the rest of Europe and as such any Standard Definition TV's bought in the UK or else where in Europe will not work in Ireland.
You can watch British and European programmes via satellite whilst in R.O.I. but not RTE.
If you have a normal TV and want to watch Irish Broadcasters such as RTE then you will need to purchase an Irish set top box in Ireland. Thier equivalent to Feeview is called Saorview.":Doh:
motorhomer
680
418
South Shropshire
Van Conversion
since 2005 (but 30 years caravanning)
Ireland is not the only country in which there is a problem with UK Digital Terrestrial TV's. The standards used are not universal!
Our Avtex works in most countries but would not work in some Scandinavian countries.
If the country you are in is not in the TV's set up list there's a strong chance the TV will not work.
