how do people find the performance of the Avtex aerial inside a PVC?
(Good/bad/indifferent?) do the steel walls block TV reception? Where are your aerial fitted to get best reception? Next to a window or skylight? Outside? On roof?
Table
No aerial will work well inside a panel van. Steel or aluminium totally blocks any signal so you're left with the windows. Simply put any aerial for any purpose other than satellite reception will work best as high as possible and clear of metalwork.
