Avtex aerial
Discussion in 'TV & Satellite' started by cbrown1360, May 15, 2016.
  1. cbrown1360
    cbrown1360 Funster
    Aug 24, 2015
    66
    15
    Lymington
    My 2 year old Elddis van is fitted with an Avtex Omnidirectional TV/Radio aerial which appears to be next to useless. I've just spent 3 weeks touring the Lake District and Scotland and I've only managed to get a TV signal on a couple of occasions. I know there are hills around but surely the locals don't go without TV. There is an amplifier so I would a expect better result or am I missing a trick?
  2. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    6,232
    11,773
    Glasgow
    Do you havean amplifier and plugged in?We get most of ssScotland for free :)
    • Like it Like it x 1
  3. Gorse Hill
    Gorse Hill Funster
    Feb 2, 2013
    1,979
    1,792
    Stretford
    The avtex aerial normal has a built in amp, if you have a avtex tv this had a powered output for the aerial look in settings to activate
  4. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    6,258
    12,694
    Kettering
    Also you will need to retune your TV pretty much every time you use it.
    Are you doing this?
  5. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,616
    2,657
    Trowbridge
    Our van has this fitted and we struggled. We got a new amplifier made by a third party with gain control and signal strength indicator and it is much better. I can't remember where I for it from though I'm sorry..
  6. cbrown1360
    cbrown1360 Funster
    Aug 24, 2015
    66
    15
    Lymington
    Yes and yes
  7. cbrown1360
    cbrown1360 Funster
    Aug 24, 2015
    66
    15
    Lymington
    Yes - every time we move.
  8. NickNic
    Jan 14, 2014
    6,258
    12,694
    Kettering
    Have you tried a signal meter, something like this
    http://www.screwfix.com/p/slx-digital-signal-finder/58244
    Just plug it into one of the outputs on your amplifier and then when you adjust the aerial you should see the signal strength.
    If you get nothing registering it could be a dodgy amplifier.
    • Useful Useful x 1
  9. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,616
    2,657
    Trowbridge
    The omnidirectional doesn't need adjusting but does have to be fitted exactly level.. I only found that out the other day and mine isn't so after Jersey I will have a fiddle and get it done.. I wonder how many others have the same issue.
  10. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,388
    3,157
    Kendal, Cumbria
    Unfortunately the Lake District has hills as well as Lakes. Most places have their own transmitters which are of necessity low power. Anywhere out of the immediate vicinity of a transmitter will need a directional aerial. Omnis are very low gain and pre-amps only help if there is at least a small signal at the aerial. Some of the local transmitters are horizontally polarised but some are vertical which won't help much if your aerial can't be adjusted.
  11. NickNic
    Jan 14, 2014
    6,258
    12,694
    Kettering
    Yes, sorry, I missed the Omni bit. It still applies though - he needs to prove the aerial and the amplifier first and a signal finder is a cheap easy way of doing that. Just ignore the bit about adjusting the aerial (y)
    Connect the cable directly from the aerial to it first, then if you get something on the finder move it to one of the outputs on the amplifier.
  12. Linda and Steph
    Linda and Steph Funster
    Jun 18, 2008
    1,375
    1,448
    Lancaster
    We found the aerial on our Elddis was next to useless (it was just a short bee-sting type. We never managed to pick up a signal no matter what we tried.
  13. dbnosey
    dbnosey Funster
    Jul 21, 2011
    98
    107
    Yes that type of Avtex aerial is as much use as a damp piece of string. I have found the Avtex STH3000 very good in the Lake District even just hanging from the skylight inside the MH. Can be used for vertical (repeater transmitter) or horizontal (main transmitter) polarisation.
    I have a Sat system but always carry the said aerial in case of trees.
    Colin
    • Like it Like it x 2
    • Informative Informative x 2
  14. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,427
    5,457
    East Sussex 01-580-881288
    [​IMG]Avtex STH3000 Caravan & Motorhome Digital Freeview TV Aerial
    Included in the Avtex STH3000 Portable Digital Freeview TV Aerial
    • Antenna
    • Pole or Wall Mount
    • Flexible Suction Mount
    • 3m Coaxial Aerial Cable
    • 12v Aerial Power Adapter
    • 12v Cigar Lighter Plug
    • Pole Mounting Kit
    • Wall Mounting Kit
    From personal use I have found this to be an excellent aerial in a poor signal area but it is essential that the power amplifier/booster as supplied is powered and on and, some TV receivers may not have a 12v supply at the aerial input socket like Avtex so use the cigarette socket power source as supplied.
    I use one in my office in garage block as there is no aerial supply out there, mounted on a pole about 9 foot high it is brilliant, I use a 12v laptop charger for supply
    Peter
    • Useful Useful x 1
  15. Muddibootz
    Muddibootz
    Jan 4, 2016
    166
    112
    North Shropshire
    I'm not sure what the make of aerial in our 2012 Elddis but ours was great to start with, then stopped working in much the same way you describe. When I looked into it, the power lead which is presumably feeding an amplifier had become disconnected which was strange because it's inside some capping so couldn't be easily disturbed. I reconnected it using some choc block and it's been fine since. Could be a common issue with the Elddis connections?
  16. ambulancekidd
    ambulancekidd Funster
    Sep 23, 2014
    863
    2,125
    Ayrshire Scotland
    Digital TV rarely works with omnidirectional aerials. The Lake district is a case in point, I've only every received a signal with a unidirectional (can be pointed) aerial in Cumbria or anywhere in Scotland, furthermore you can receive extra channels in the same area by turning your aerial through from horizontal to vertical. This is especially true in Dumfries & Galloway where some signals are received from the Caldbeck (Cumbria) transmitters. The TV needs to be retuned between the two variations.
  17. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,616
    2,657
    Trowbridge
    After I changed the amplifier on ours I get a pretty good signal most places I would expect to. It is susceptible to van movement though which I discovered recently is due to it not being fitted level. It has adjustment to avoid that.
    I would say if you are suddenly getting no picture where you previously had a picture it is either a failed booster or a wiring issue.
  18. teensvan99
    teensvan99 Funster
    May 17, 2015
    226
    246
    Margate
    Get a maxview crank up sat system and bin in the avtex. We R sitting at Piesport Germany watching Emerdale should say Ann is watching it
  19. ambulancekidd
    Sep 23, 2014
    863
    2,125
    Ayrshire Scotland
    Programmes like "Emmerdale" can cause serious damage to your......sanity, tune it out immediately lol, but yes your absolutely correct a decent satellite system is by far & away superior.
  20. RichardB
    RichardB Funster
    Oct 19, 2013
    223
    111
    East Yorkshire
    Just had a weekend away and had no TV - we have a 2013 Elddis with the Avtex black thin whip aerial and also have a new Avtex TV connected to it. I've got a signal strength meter and it shows full strength (80)...When I tune the TV in it says that its found 90 TV channels and 30 or so radio stations..
    All looks good until you try to view a channel - the pictures comes on, breaks up, goes away, and then does this continually or in some cases goes black and then eventually the TV says No signal and retune.
    Do anyone have any idea what I can try to do to fix it other than replacing it!
