Autotrail external door restraint replacement (1 Viewer)
Bazzermc
54
40
Wiltshire
Autotrail Cheyenne
I'm a newbie
Hi, we have a 2009 Autotrail Cheyenne and the external restraints that hold open the doors are tired, which is a pain with the upward opening garage doors.
They are pop riveted to the external skin, I can drill out and screw new ones on, but I am concerned how strong the outer skin is and how to strengthen if they pull out?
Also have same problem with the awning light screw fixings, which don't tighten up.
Anyone replaced the door restraints or strengthened screw fixings in this body shell?
Thanks in anticipation.........Barry
Jul 31, 2014
1,930
3,241
West Yorkshire
EuraMobil Activa 820HS
I shall look forward to any replies on this because my door retainer is also pop riveted and I'm considering replacing it like yourself.
Aug 27, 2014
1,910
3,931
Shropshire
McLouis Tandy 640+
Since 2014
Different van, but mine had these retainers, which are rubbish:-
Broken Link Removed
So for the main habitation door I replaced it with one of these:-
Broken Link Removed
Which is a lot better. I just screwed it on to the outer skin, with a blob of white Sikaflex underneath - the screws being mostly to hold it firmly in place whilst the Sikaflex goes off. The Sikaflex also ensures the screwholes are sealed.
Jul 12, 2013
3,872
5,275
The City of Henlow
Adria Supreme
Since 1980
When I asked my dealer for a new retainer, he said take ("take") two or three, the plastic only lasts a short time before losing its strength. I took one but only weeks later I had to buy another in France. My van is a Dethleffs but uses similar retainers that are screwed on. If yours are pop riveted on, I would be inclined to use new pop rivets, for I doubt there will be enough strength in the little pop rivet holes to take a screw. Anyway, you do not know how thick the wall is.
Feb 8, 2014
1,662
4,673
Sheffield
Eldis Majestic 115
Vans and tugs since mid 70's
On my 2011 Tracker the door retainer is far too near the hinged door so no wonder it looses its grip so easily. I decided to just use a bungee to hold it open braced from the door handle enclosure to the wheel arch.
