Autotrail Entrance Step - Settings Change (1 Viewer)
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
Hi Funsters,
I recently came across a system setting change on the Sargent website for the electric entrance step on pre 23/11/2009 build number 30154 Autotrails. This simple change to the settings by removal of a link on the EM50 Intelligent Interface Adaptor results in your step opening when unlocking your Motorhome, it will then remain out until either the engine is started, or the button inside the habitation door is operated to raise the step. This does away with the step continually raising and lowering whenever you lock/ unlock the MH when parked up. This will no doubt extend the life of the steps motor and mechanism and facilitate the use of a draught skirt when pitched. I've completed the setting change and it operates just as described on the link.
Anyone interested in this change can check it here.....
http://sargentshop.co.uk/WebRoot/Daily/Shops/eshop328964/MediaGallery/EM50_Instruction.pdf
Lance. :thumb:
JaG
Oct 30, 2008
1,375
1,458
Chesterfield
Autotrail Cheyenne
Since 2008
Spot on, just what I have been looking for, I think. Ideally I would prefer it only works on the button inside the door. Unfortunately the link does not work for some reason. Maybe because it has been on for so long.
We use separate steps for wife to get in and out as she is disabled. It is an absolute pain when we unlock the motorhome after sleeping and the step shoots out and either moves the caravan type steps or worse still, jams underneath them.
Al n Val
2,266
5,615
West Yorkshire occasionally
Rapido i1090 Distinc
since 2018
if you press and hold the settings button on the panel above the door it gets you into the service menu, this then allows you to change the setting for the step so its manual only and operate with the button as you enter/leave the moho.
Al (y)
JaG
Oct 30, 2008
1,375
1,458
Chesterfield
Autotrail Cheyenne
Since 2008
All sorted to exactly what I wanted. Removed Jumper 2 from the EC50.
Now when I use the double step for Jean to get in and out of the motorhome the step does not come out when I unlock the door. When I am in and out of the motorhome I open the step with the button inside the door. When I lock it with the remote, or start the engine it goes back in. Perfect.
Thanks for your help guys.
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
Al (y)
Hi, I have the same panel.
Which is the settings button please?
Theonlysue
6,104
7,383
Essex
Not long enough!
Al (y)
It’s the one that looks like a cog from memory 😉
I can't see it ....
Theonlysue
6,104
7,383
Essex
Not long enough!
Mine is ecu325
JaG
Oct 30, 2008
1,375
1,458
Chesterfield
Autotrail Cheyenne
Since 2008
It doesn't work like that on the EC325. There are no settings for the step. Removing the jumpers indifferent sequences, like my post above does work.
Oct 10, 2018
1,991
1,124
Bracklesham Bay, West Sussex
PVC
There is a download for the Sargent EM50 (showing step configuration settings) in Manuals for Motorhome stuff , section of Resources and although it is for Autotrail Motorhomes the information in it should be the same for other Motorhomes with a Sargent EM50 fitted along with a Sargent ECxxx PSU
JaG
Oct 30, 2008
1,375
1,458
Chesterfield
Autotrail Cheyenne
Since 2008
Do you know what the link is and how it's done? It would be helpful as I have a 2009 Autotrail with the EM50 behind the driver's seat.
Oct 10, 2018
1,991
1,124
PVC
Hello JaG ,It is in the Resources section that is on the top (blue)line of this page and you can download it , it has information about what jumper pin settings operate regarding the step/central locking. (I do not have a EM50 in my van so cannot help with more details , but pins being joined or not in the EM50 seems to the way to alter things) I have read that if the pin 1 is removed it will stop the step retracting when the van is locked but it will still go in if the engine is started, but I do not know this for a fact. If you need more information Sargent Electrical are very helpful and may be able to explain things more clearly. 01482 678981 (although you may find that now you have to -Raise a ticket - to request information from the support team online through their web-site)
JaG
Oct 30, 2008
1,375
1,458
Chesterfield
Autotrail Cheyenne
Since 2008
Thanks, I have done that. Removing the centre bridge means it does not come out when unlocked, only manually but does go back on when starting and locking. Just what I wanted as I use a double step for wife so don't want it to pop out but electric when on my own.
