Autotrail electrics question ( again LOL !! ) (2 Viewers)
23,836
72,512
Not getting ANY sense out of Autotrail and Sargent has promised to call back and failed.....
The system in the van seems to draw about .5 of an amp all the time, even though the panel is ( supposedly ) switched off.
Under the seat there is a secondary control box.. There is a red LED on all the time..
A) Should that red LED be on all the time ?
B) Should there be a current draw when everything is switched off according to the panel ?
I can understand a few milliamps to keep the panel clock going and of course it will effectively be in some sort of standby mode, but .5 of an amp seems a LOT !!
Scout
3,959
121,359
South Yorkshire
chic c line
John you may need to recalabrate the system. There's some posts on here about it. Im at work af the moment but wben I get home ill look up my notes to see how its done. Memory's not what is was
23,836
72,512
Hiya mate,
not been going by the panel but by my own external meter..
Or do you think the current draw is being caused by something that does require calibration ?
As a matter of interest though, the voltage meter always reads .4v down on what it really is..
I have the original info and have tried following the re-calibration procedure in that but it always stays the same, so any help on calbrating you can give really would be greatly appreciate (y)
Scout
3,959
121,359
South Yorkshire
chic c line
the thread about this is here,
but this is what you need to do to recalibrate the amps drawn, on the pannel over the door select the amps draw option, press and hold the left arrow key, the system will read "recalabrating" and the set the system, release the key and the reading should be zero amps ( if all power is off). I had to do severail times to achive this.
however saying this, you may have newer unit than me, I have the older psu 2007 with the over door display/switch unit EC200
Im not sure about the underseat led as its not fitted to mine
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Hiya mate,
Is a quality multimeter (fluke) if so has it been calibrated (done yearly) if not it's reasonable to expect it's the meter althou 500mA seems a bit high unless it's a Chinese import
longdog
Banned
Apr 16, 2013
255
287
Funny you should say that...... My Ace Adventurer has done exactly the same since I have had it. I have had it checked and nothing untoward was found, I also had a brand new control panel from Swift and there is still a constant draw just exactly as you describe.
I'm going outside to try this re calibration thingy right now!
tonka
10,834
21,541
Cannock, Staffs
A class Burstner 800
Since 2000
What PSU do you have ??? EC500 ??
I found the same and queried it with Sergent.. Seem's that is normal (although I had 0.3 amps) unless you turn off the whole system via the Shutdown button on the PSU.. However, if you do a full shutdown then any solar panel fitted and regulated by the PSU will then only charge the Leisure and not smart charge both..
lunarman
2,156
2,451
South Glos
since 1994
On our van (Pilote with Schaud electrics) ceratin items are live even with the 12v panel turned off from memory this includes - Truma Frost Protectiom, Gas Cut off, Fridge Electrics.
This is to protect "essential" services in the event that the system shuts down due to "Low Voltage"
eddie
8,159
41,278
Taunton Somerset
RV
since 1989
Could you post a picture of the box? and does the quiescent drain increase if you turn the ignition on (without starting the engine) and turn the blower and the head lights on?
Eddie
23,836
72,512
Fluke, a quality meter ??
true about 5+ years ago but the newer ones are real awful.. all over the place..
I use all sorts of meters and check them for most functions quite regularly ( I use a scope and regulated controlled PSU both of which get redone every two years by a tame bod at a certain USAF base local to me where they do all manner of calibration stuff )
Sooo.. Did the recal thing and it was the same ( actually, before I did it the panel was reading an amp, but that dropped to .5 amps in line with my external meter after recal )
Started unplugging stuff and when I finally got that led on the oddball box to go out the draw dropped to .1amp.
That box is called an EM50 interface unit and seems to control ( of all things ) the rear lights.
The Sargent unit its self is a 225 and the control panel fitted is apparently the wrong one and is meant for later units. ( but it seems to work more or less ok so not worried about that )
I shall continue investigating but in the mean time I have bought a battery isolation switch so I can ditch everything completely and just leave the solar panels working.
Oh, the solar panel system built in to the Sargent is pretty limited by the way, and to be honest not that efficient either..
I would recommend anyone using a solar panel in conjunction with a Sargent box, buy a decent solar panel regulator and use that instead (y)
23,836
72,512
Eddie
I shall run checks on that tomorrow Eddie.. Will try and take a picture of the box as well
One thing I have learnt
Sargent in general are really VERY good and very helpful.
They know their stuff and previous to this latest issue have always been on the ball. ( I think maybe my call for help was not passed on due to an oversight ... which we are all entitled to once in a while :) )
The kit is extremely well made but to be brutal is overly complex.. Methinks they are over egging the whole thing to be honest..
It seems they started off with something that did the job and have had an ongoing development policy ever since, constantly 'improving' the various systems all the time.
Perhaps it would now be better to start over and go with something a little more K.I.S.S. ;)
eddie
8,159
41,278
Taunton Somerset
RV
since 1989
Ah Have you got a tow bar fitted? more importantly towing electrics? and is you chassis a CAN system?
Scout
3,959
121,359
South Yorkshire
chic c line
so the re-calabration did work, as you now have it reading the same drain as your meter,
23,836
72,512
It is canbus and I do have a tow bar and the relay box.. But the issue was there even before that was fitted..
Good idea though Eddie :D
Yes mate :) (y)
Worked a treat but drain still a little high so am furthering the investigation
23,836
72,512
Just remembered.. drain is about 1.8 amps as soon as I press the on button..
More issues I am thinking.....then I realised it was the bloody Pace box doing the biz, so at least that is no mystery
Gorse Hill
2,364
1,944
Stretford
Obviously on top of things jaws, pretty much checked everything I would have
Will have a look at the schematics for the Sargent to see if we missed anything mate
Chris
21,056
278,943
10 years
x=mc2 x amps isn't it?
23,836
72,512
Have you got the maps of the internals Chris ?
I have all the basic ones that show what is connected where but ( understandably ) Sargent were not willing to release the actual circuit diagrams.. If you do have them would love a copy !!
Ummmm..
That looks like it might be the formula for the flux capacitor !! A bit of everything in there (y)
23,836
72,512
Once I got to look at the box properly all the info is there ( apart from what that bloody LED is !! )
23,836
72,512
I know this sounds stupid, but I cannot remember !
Fiddled about so much and made so many checks it is lost in the muddle .. I will be back out there again tomorrow so will see what it is ( and write it down )
23,836
72,512
The pace box draws .6 on standby and .9 up and running... actually better than I expected.
I have but one mystery to solve now ( apart from that LED which I have figured out how to over come )...
The leisure batteries are wired to the Sargent separately..
Two distinct pairs of wires..
They each have their own connection on the box.
BUT
Are they merely connected to each other inside the box ?
They do not appear to be as there is usually a .2v potential difference between the +ves.
If they are on circuits isolated from each other in the Sargent then I am wondering if the batteries are getting an equal charge from the solar panel system..
They SEEM to be as that differential does not vary but......................
I am tempted to simply put a jumper cable between the two +ve's and fire it up, but have resisted the temptation so far due to potential damage to the Sargent.
Speaking to their tech chaps shed absolutely no light at all !
eddie
8,159
41,278
Taunton Somerset
RV
since 1989
Are you sure that they are wired separately? Often if you lay the wires out adjacent to the battery, the loom is wired to a "Y" connector to allow a 2nd battery connection to be easily made, however the 2nd battery loom was quite long! Consequently it looks like there are two separate looms.
In essence (from memory ;-) the Positive is Brown with a Blue trace and the Negative is White with an Orange trace.
With the standby voltage as high as it is, I would unplug it or add a switch in series to kill it.
23,836
72,512
Yup, absolutely positive Eddie.
Two separate wires, individually fused going to both the EM50 unit and split off to the PSU ( connector M on the EM50 and B on the PSU
I agree about the switch and ordered these for that purpose:
I ordered from a company called UKautospares on fleabay but they sent me some sort of crappy rotary type switch .. Mailed them and they said send it back for a refund.. ( I will be dealing with that in my own way !! )
I am gonna ring Sargent again this morning to see if I can get a more definitive answer re where the separate feed wires go once inside the PSU
23,836
72,512
Just off the fone to Sargent.. ( they really are NICE people ! )
While the batteries are on separate looms they are actually directly connected to each other inside the PSU..
That must mean I have a slight resistance in one of the connections going to one of the batteries.. Quite probably one of crappy fuse holders ( think I will just replace them with some decent bits of kit rather than mess about )
The chap I spoke to also answered a couple of other questions I had and confirmed the control panel fitted in the van, while in many ways better, is not ACTUALLY the right one for the EC225 unit.. The 225 has no feed to the panel ref the EHU which explains why, no matter what, the panel assures me I am not on hook up ! LOL !!
Andddd.. Confirmed the quiescent current to be exactly as he would expect.. I mentioned I thought it a little high and got an ummmm.. back ( so quite possibly this issue has been resolved on the later versions of the PSU )
As time goes by I am getting more and more info and more and more to grips with this overly complex system
23,836
72,512
Update..
Soooo
Today I went and double ( treble ! ) checked this issue with the leisure batteries having a different voltage on each ( it is called a potential difference in tech speak :). )
It is not a lot.. around .2v, but it is there and should not be.
I found one of the inline fuse holders had a poor connection so replaced BOTH so as both batteries have identical set up.
Problem is still there.
I removed various bits of trim and cupboards and traced the wires through.. Both feeds in good condition.
Removed both feeds and using a fairly sophisticated set up checked for any resistance in the wires ( starting to get desperate as you can tell ! )
All check out fine
Next, ran the same checks on both the earth feeds.. again, all fine
Using pointed probes to get through the feed wire insulation I check the voltages of both as they enter the PSU.
Same result.. small but measurable difference between them
So where does that leave us ?
All the battery connections and feed wires are perfect
The feed wires I have been assured are connected to each other within the Sargent unit.
So the ONLY possible answer is that I have a poor joint ( somehow ! ) within the Sargent.
Next job will be to remove the PSU front panel ( not easy where it is located ) and physically confirm what I have been told.. that the wires go in to a common brass connector bus-bar.
If they do I think I will give up trying to be clever and simply put a nice thick jumper cable on both the +ve and -ve terminals of the batteries to physically join them at the batteries.
If they do not connect to a brass bus-bar but instead go to two separate terminals on the board, I am gonna have to strip the board right out and see what on earth is going on behind it !
More info ( for those interested ! ) as and when .....
Got Lincoln this weekend so doubt I will have much time for further play until next week !
