Autotrail Arapaho 2010 rear view camera adjustment??
Discussion in 'Tech/Mech General' started by Kenny M, Aug 30, 2016.
  1. Kenny M
    Kenny M
    Mar 21, 2016
    13
    9
    Spain
    Does anyone know how to adjust the rear view/reversing camera. It is housed in a small white cover with a transparent window for the camera. I can see no fixings, internally or externally to remove the cover so as to adjust the camera.
    Regards,
    Kenny M :)
  2. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,485
    6,755
    St. Helens MERSEYSIDE
    Hi Kenny I have a similar camera and I tried to adjust it and without taking it off completely, I could not see any way to adjust it seems to be preset and permanent.
  3. peterc10
    peterc10 Funster
    Jul 5, 2013
    4,035
    2,969
    Tunbridge Wells
    Sounds like a factory fit camera. In that case it will be best to tell us what motorhome you have to see if others with it have managed.
    • Informative Informative x 1
  4. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,755
    8,006
    The plastic cover is just help on with Sikaflex type adhesive..
    If you are careful !!!!! You can get a blade in and cut the sealant away or use a cheese wire / stripped down electrical cable to slice it away from the back.. Did it on my 2005 model as the camera failed and i fitted a new one.. Tidy up the area and re-seal back on...
    But be careful as a replacement may be hard to get ie an Autotrail part and so cost a bit...
  5. Speve
    Speve Funster
    Jul 29, 2013
    2,279
    2,183
    Salisbury
    It's in the title
    (y)
  6. peterc10
    peterc10 Funster
    Jul 5, 2013
    4,035
    2,969
    Tunbridge Wells
    OOps sorry :oops::oops::oops:
  7. MikeD
    MikeD Funster
    Dec 21, 2011
    2,231
    1,934
    London
    I was at a dealer when they were removing the cover it is as previously stated just glued on using a sikaflex type glue.
    The fitter had a devils job getting it off
  8. tonka
    Jul 2, 2008
    5,755
    8,006
    Similar to removing solar panel brackets.. I found some stranded copper mains cable.. Stripped it down to just one strand.. Then used that like a cheese wire moving in back and forth while applying a little pressure.. Went like a hot knife through butter.. :)
  9. MikeD
    MikeD Funster
    Dec 21, 2011
    2,231
    1,934
    London
  10. Kenny M
    Kenny M
    Mar 21, 2016
    13
    9
    Spain
    Many thanks for all the help.
    Regards,
    Kenny M :dance2:
    • Like it Like it x 1
