Autoquest 130 Wood Delaminating (3 Viewers)
Dubiousp
233
45
Hampshire
Eldis Autoquest
First
Good evening all I have a 130 0n a 09 plate for some reason some of the wood panels at the rear of the seats and lower cupboards the facia laminate is peeling away. I think possible PVA or similar would work has anybody carried out the repair or have any advise
DuxDeluxe
14,659
72,818
Planet Zog
A woosh bang van
If the veneer only is peeling away then some sort of contact adhesive should work. Rightly or wrongly that would be my choice, rather than PVA. Cheers
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
The only problem with your ordinary contact adhesive is you need to coat both surfaces with the stuff, and let it go dry to the touch... before bonding or putting together..
Which could be a problem unless the veneer is taken completely off..
My solution would be,,,, as long as there is a loose edge would be to use or try this... a lot thinner than your normal contact adhesive,,, (y)
http://www.screwfix.com/p/no-nonsense-contact-adhesive-natural-500ml/32657
PP Bear
7,820
28,842
Kent, UK
Auto Trail Dakota SE
Sorry to hear of the delamination, but what's caused it I wonder?
Possible damp or just humidity?
Good luck with the repair :)
Jan 24, 2010
2,440
4,850
Adria Twin
Could try reheating it as it may just be the glue wasn't set right first time
use some oven paper and and iron - worked on some bits in ours that did the same
Nov 21, 2011
64
31
ESSEX
Elddis Autoquest 400
7 years
Its quite common in an Eldiss, though not exclusively, mostly caused by the use of the cooker. Ours started doing it on the Bathroom door. Always leave good ventilation with the hob on. The underside of the cupboard above the hob suffers the most our really peeled off there.
