autocruise stardream
Discussion in 'Motorhome Chat' started by smiffy502000, Aug 16, 2016.
  1. smiffy502000
    smiffy502000 Funster
    Aug 5, 2012
    220
    118
    sutton coldfield
    hi all.does anyone out there own an autocruise stardream circa 2007. or similar model, that could help me find out how to activate the built in solar panel regulator. the book says to contact the dealer for activation details. any help would be welcome. cheers
  2. neverguess
    neverguess Read Only Funster
    Aug 17, 2016
    spain
    Hi, Ive attached the instructions in pdf format, I couldn't wire mine to the control panel as it will only support a 100watt solar panel and I fitted a 135watt, good luck!
    • Like Like x 1
  3. smiffy502000
    Aug 5, 2012
    220
    118
    sutton coldfield
    hi and thank you so much for sending me this file. sorry its taken a while to get back to you, only just got home. iv asked so many so called experts who have looked at me as if I was talking cobblers, never heard of having to use a code to fit a solar panel...I must of heard that line a dozen times, iv tried to explain that it is just to activate the button on the panel, still blank looks .anyway thanks again and I will see if it works. hope I don't blow the the lot up!! cheers and kind regards
  4. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,583
    5,672
    Yr Wyddgrug
    Good to hear you got there eventually. Good luck with the code(y)
    • Thanks Thanks x 1
  5. smiffy502000
    Aug 5, 2012
    220
    118
    sutton coldfield
    thank you
