Auto- Sleeper Duetto (1 Viewer)
Sep 22, 2014
1,385
2,597
Suffolk UK
Auto Sleeper Duetto
Since 2014
I am considering buying an Auto-Sleeper Duetto year 2002, it is in very good condition, however it has done 85 thousand miles, is this something to be concerned about? Any comments would be useful.
May 31, 2015
11,680
44,523
Cornwall
Ducato PVC
Getting Better
Diesels are meant to be run, I rather have one that's been on the go then sitting around in storage... If it's been serviced regular with oil changes then it wouldn't bother me.
It also means that the previous owner has been on the road enjoying the motorhome then sitting in the garage for repair..
I buy luxary cars with about 100k miles on and run them for another 100k, I get them serviced regular and it's the body work that go's first..!
Check service record, AA inspection is quite reasonable...
normanandsue
1,871
21,571
Dunfermline - Scotland
van conversion
Agree with Sas r us, the higher mileage should be reflected in the price. If not having AAinspection slide underneath and check for oil leaks front and back. It can be cotly having oil seals replaced. Also check when timjng belt was last changed.
Ivory55
6,017
14,534
North West Norfolk
Since Feb 2012
If it's transit based , you could look on the transit owners forum for what to check on the base vehicle. Would give you a heads up for any problems that you might not think of.
Indy259
Sep 22, 2014
1,385
2,597
Suffolk UK
Auto Sleeper Duetto
Since 2014
Thank you very much all three of you, , I will check underneath for oil leaks, it is transit based so will look at the website. It will also have new MOT and habitation check it was just the miles that were worrying me, and I think you've all sorted that.
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
We had a Duetto(2003), which we sold in 2007, but not with a great mileage on the clock at that time ..... it was a great little motorhome for our first venture into the world of touring and we only changed to get more space.
The Transit is a very good vehicle being capable of covering mileages well into the 1-2K so long as it has been maintained and serviced through its life.
They are of course built to withstand a hard life as they receive from many builders and "white van men"!
If you are buying privately it may be worth having it professionally checked over or have a well experienced friend with you when viewing.
Terry
11,932
9,084
Lincolnshire
Can't remember ;)
Mileage is nothing(y) but do check around the back axle fixing points and around the rear inner wheel arches carefully -they are prone to rot and expensive to fix as most of the rear inside furniture has to come out - If sound then they are a good vehicle and hold prices well -provided you don't pay over the top they are a good buy(y)
terry
Indy259
Sep 22, 2014
1,385
2,597
Suffolk UK
Auto Sleeper Duetto
Since 2014
Thank you very much, I'm getting a list of things to check from you all, as you probably gathered I'm a mechanical novice, checking oil and water OK anything else I'm learning.
Minxy
32,656
66,553
E Yorks
Carthago Compactline
It works out at around 6,500 miles a year so not a massive amount as these tend to be used as a sole vehicle and therefore often have higher mileages.
Check the service history and go on line and check the MOT status here to see if anything was 'advised' or 'failed' in recent years.
https://www.gov.uk/check-mot-status
I'd advise you to have a garage give it a good look at (not the one the seller uses!) so that they can let you know if there's anything that needs doing which could give you an edge when negotiating on price but also make sure you're not buying a lemon.
ambulancekidd
Sep 23, 2014
10,369
28,396
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
We had Transit ambulances from the same era & they went on to do 350-400k with only normal service costs (clutches etc) & there can be no harder life for a vehicle. However a small word of caution. We had 3 Transit ambulances that went into service on the same day. Two went onto 3 shift systems so were running 24/7 & the other went onto a mon-fri 8.30-16.30 now aftern 3yrs or so, the two vehicles that were on 24/7 were seriously quick but had the usual rattles that came with abuse but the day shift only vehicle wouldn't pull a soldier off a woman but were rattle free!
I've had a chat with a friend of mine who MOT's commercial vehicles & I asked him about weak points on these Transits. The usual words of caution as mentioned by other funsters but further to that he says that the front chassis legs rust from the inside out & the only sign of this is that the legs have a slightly crushed (flattened) look about them. This is unlikely in the case of the vehicle your looking at but worth checking for.
Good luck...Robert.
Indy259
Sep 22, 2014
1,385
2,597
Suffolk UK
Auto Sleeper Duetto
Since 2014
Thanks both. I did check MOT Mel at your suggestion all OK and Robert, thanks for your info.
