Anyone use cycle rack - Plastic 'Sewage pipe' storage? (1 Viewer)
wingman
1,217
3,333
Romford, Essex
Coachbuilt Lo-Profile
Since 2012
I've seen a few Moho's with a length of large bore plastic 'sewage pipe' attached to the bike rack. I presume this is to store large Morocco mats or groundsheets etc?
For convenience and space-saving, I quite fancy getting a lump to store my windbreak and poles. Here's a few questions.....
  • Does anyone on here use this idea?
  • What's the proper name of the pipe?
  • What is the O.D? Is it 150mm?
  • What method is used to fix the pipe to the rack?
  • How does one attach the pipe's end caps?
Thanks in advance
James
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
It's called soil pipe...
Two types... Above ground ( looks pretty in black or grey) below ground - orangy brown....
Chances are if you nip outside and look at your upstairs soil-stack (loo waste) ...
That'll be it :)
Edit: type diy. Com and look at drainage section :) for fittings etc :)
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
We have one in our garage .. it stores flag pole winder awning rail and stuff. Ideal. Think we probably copied it from techno or someone similarly gifted.
It's not soil pipe and it came with end caps that I put foam in
Nov 11, 2013
1,959
6,893
Tewkesbury
Hymer T-SL 668
March 2014
I saw one somewhere fitted vertically to the back of a m/h that was used to store a large number of toilet rolls......
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
Another use for a bit of soil pipe, end stopped and two bungee cords. Used for - Fishing rods, walking poles, french bread sticks and rolls, bottles of wine, cans of beer.The soft bag is replaced with tackle box (bungeed).
Apr 13, 2012
5,545
18,775
Mobilvetta Euroyacht
1996, then break 'til 2011
That'll be it :)
Also available in white(y)
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
We use a longer one that keeps all our poles for the awning together and it attaches to the inside wall of garage area out of the way.
43,331
49,463
The Orange pipe is not UV stable.
It may take years but will degrade.
I used a length to store the sewer dump pipe on my RV.
cross wire one end and a pin and R clip at the other so the 4" flexible sewer pipe could dry naturally.
Charlie
3,211
3,639
Auto Sleeper Kemerton.
Im a newbie
Do you me degrade as in colour fade ?
scotjimland
2,335
10,107
A Woosh bang
Have a length of square plastic gutter in the garage which holds two lengths of flexible hose for the grey waste .. was already fitted when I bought the van.. works well.. easy to store the pipes without having to feed them into a pipe.
Same idea could be used for poles, windbreaks etc ..
Nov 9, 2015
366
451
Shenfield, Essex
Carthago Malibu PVC
35+ years mainly in VW's
Hi Wingman
I used to use one on my old VW T3 to hold my windbreaks etc. It rested on the bumper and was securely held in place by my towbar mounted bike rack. You would need some soil pipe, the to close the ends either use a socket plug and one screw on end cap or alternatively use two end caps.
I see your not far from me, if you wanted to have a look at mine and see how you could fix something similar to your van, let me know
Trevor
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
In Australia I'm told it's not unusual to see camper vans with lengths of black large bore pipe mounted on the roof, sealed at both ends and with a tap sticking out of them.
They're solar water heaters.
Same principle might work in the Med in summer - the black PVC hot water bags certainly work in southern Europe.
Feb 16, 2013
19,735
52,033
uttoxeter
ambulance conversion
50 years
When we were in jesolo saw loads of cafes and ice cream places on the beach with large coils of large diameter black hose on the roof for hot water
wingman
wingman
1,217
3,333
Romford, Essex
Since 2012
Hi Wingman
Trevor
Thanks Trevor, just noticed your kind post. Will send you a PM. James
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
We use a fishing rod tube (with end caps) in our garage fixed to the overhead bed slats using strong Velcro (y)
TheBig1
17,630
43,304
the plastic loses colour and goes brittle
somewhere in my yard I have a length of 150mm drainpipe with screw on end caps each end. it came off a work van and was used to transport long lengths of plastic conduit. it was sprayed red to match the van. 10 plus years later its still solid. a plain brown one from another van is degraded and has a hole and crack in where its been bumped
Charlie
3,211
3,639
Im a newbie
Plastic guttering Soil stack and other goods discolour when they are made using recycled materials. If they are made using what in the trade we call virgin materials they will not fade or become brittle.
Basically it's down to the quality and price point of the goods we buy.
Cheap stuff fades and goes brittle proper stuff does not .
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
I believe it does have something to do with the colour impregnated during manufacture. "Natural" (White) Polyester (Rope) material is affected by UV, and degrades far faster that (say) Orange or even Black. Not sure of the chemistry. But when "Man made" ropes started to appear on Ships, it was noticed that the "Natural" ones broke down and failed faster. I believe the modern ones are more resistant to U-V?.
BTW, We had a near fatality on one ship, when a Natural (coloured) Sling failed, the load narrowly missing a Sailor. One of a batch, because it was nearly new the BOT surveyor had it tested, and the summary was that it was down to storage. having likely been left out in the Sun during the voyage, where the others where stored in a deck house!.
The use of this method (Soil Pipe) was favourite with a lot of R-V owners to carry Sewage Hose, I had two on my first R-V under the Rear fender (surplus from a self build!!). The second R-V had a Roll up flat hose and a Macerator!.
Pete.
Malcolm Bolt
1,107
2,600
Harrogate
old A class
since 2011
I saw one camper with an large old radiator painted black across the roof. It came complete with a shallow "header " tank. Proved very effective providing ample hot, hot, hot water for the single traveller.
PeteH
6,853
9,030
Rapido, 999M.
Now for the "Posh" Bit. the Winnebago (left). Had an extra coil in the Hot water tank, which ran engine cooling through the cylinder. Arrive on site, or stop for lunch.= Hot water!.
Pete
