Anyone know where my 5th gear has gone? (1 Viewer)
Oct 2, 2011
864
571
Scotland
Since 2011
Hi, I was driving back from Edinburgh today. I just got over the Forth road bridge when I noticed the revs shoot up and the speed start to drop. 5th gear had gone. I can get all the other gears but nothing for 5th. Can any one suggest what has happened? Peugeot Boxer 2003 2.0 31,000.
MikeD
3,936
3,697
London
IH PVC
Since 2012
Water in the gear box
I suspect that there is water in the gearbox.
I am no expert but there have been issues with the scuttle drain tube not being sealed and allowing rain water to enter the gearbox through the gearchange shaft.
Do a google search "water ingress into gearbox of peugeot boxer"
Hope this helps :thumb::thumb:
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Maybe it voted for independance!:Smile:
Fifth gears on older boxes were prone to failure due to fact they were sometimes an add-on to a four speed design.
Hopefully its just a selector linkage problem, but if not I read somewhere that the fifth gear 'pod' is easy to access and strip for inspection without removing the gearbox.
Hopefully someone who has experience of these units will be along soon.
Edit, info here-
http://www.seered.co.uk/fiat_mmm.htm
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Earlier incarnations of the Boxer/Ducato/Relay had an occasional issue with fifth gear because it was outside of the main box casing and had a propensity to come undone and drop off, which is almost cetainly what yours has done. Its a reltively easy fix as long as you didn't do many miles afterwards as that can cause swarf to accumulate in the box which then needs to be stripped and checked. Geo probably has more experience than myself.
D.
Nov 3, 2013
3,170
9,386
Portugal
Fiat Ducato Auto Wildax
C/van since '73 .M/h.2009
Hi.
dave newell beat me to it,i was going to suggest that had you pulled up and got out,taken your shovel from the motor,walked back up the road and...... Result:ROFLMAO::ROFLMAO:
Tea Bag
gordoncbrown
Oct 2, 2011
864
571
Scotland
Since 2011
Thanks for your replies. I've just called the garage that I use and booked in gfor it's MOT next week and they will look at the 5th gear at the same time. They have had to sort this before on others so at least they know where to start looking. No smiley yet until I see the bill.........
43,331
49,467
no smiley for this Gordon.....plus labour.
Ad says ducato but they are the same part.
Broken Link Removed
TheBig1
17,630
43,326
a member on here repaired his himself and chronicled his progress including photos
Broken Link Removed
will give you a good idea what will be involved
gordoncbrown
Oct 2, 2011
864
571
Scotland
Since 2011
Absolutely sailed through the MOT. However, when they had a look at hte 5th gear issue the nut and everything seems to be tight. They can see it selecting 5th gear ok it is just not driving... They are awaiting an expanded gearbox pic and some more info from Peugeot. Anyone got one tucked away?:thumb:
gordoncbrown
Oct 2, 2011
864
571
Scotland
Since 2011
The plot thickens. The garage has got the drawings but they don't seem to shed any light on the subject. It is definitely not the nut that has come off. They say that the older ones that had the issue with the nuts falling off were double nutted where this one is a nut and a circlip and is a newer version. Any one able to come up with another suggestion?
gordoncbrown
Oct 2, 2011
864
571
Scotland
Since 2011
Ah well, looks like it's going to get expensive. Booked into a gearbox specialist for Thursday. :Sad:
43,331
49,467
i think one of the problems was oil feed to the 5th gear extension.
Wouldnt be surprised if the shaft splines or gear wheel internal splines hadnt worn and broken off leaving the gear to spin on the shaft.
gordoncbrown
Oct 2, 2011
864
571
Scotland
Since 2011
Thanks Papajohn, any idea how much that sort of thing typically costs to sort?
I'm sitting down......
JockandRita
11,462
150,163
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Gordon,
Did you have a look at the link Big1 put up for you?
Broken Link Removed
The 2 x sets of 5th gear replacement parts alone, from Fiat/Citroen/Peugeot, are just short of £635 including VAT.
Good luck with it. :thumb:
Jock.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
I have 2 sets of 5th gears for sale (one set high & one set low ratios) if anyone's interested.
As new very low miles, used them when experimenting with gear ratios on last van(05 Fiat).
gordoncbrown
Oct 2, 2011
864
571
Scotland
Since 2011
I will let the garage know. I may be in touch. Thanks
gordoncbrown
Oct 2, 2011
864
571
Scotland
Since 2011
Well, it's repaired and I pick it up after work tonight. I might need picked up once they hand me the bill though.......
gordoncbrown
Oct 2, 2011
864
571
Scotland
Since 2011
Back on the drive now. £550 lighter but all seems well. Ready to roll for the season. If anyone in Scotland has gearbox issues I can recommend Charles Butler in Forfar. Reasonably priced I think, and I know a few people from Forfar and they seem to have a good reputation. :thumb:
JockandRita
11,462
150,163
Lincs/Cambs border
N+B Flair 8000i
You did well there Gordon. It cost me nearer £650 just for the 5th gear and syncro gear sets. :whatthe:
Cheers,
Jock.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Heard of this chap. He has a padlock on his sporran, it seems......:winky:
gordoncbrown
Oct 2, 2011
864
571
Scotland
Since 2011
tell us all what was wrong with it then:Smile:
It had stripped the 5th gear and synchro. As expected the most expensive bit of the bill was parts. I suppose as they are transmission specialists they know their way round gearboxes and get the job done quite quickly , probably quicker than a general garage that wants to stretch themselves a bit.
