Anyone got a Webasto Dualtop RHA102/Evo 8? (1 Viewer)
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
We have a Webasto Dualtop RHA100. The boiler has sprung a leak and, since it is £600 for a new one, I am considering an upgrade.
I have in mind an Evo8 with the 2000w electric element and programmable controller.
Whilst the unit is phenomenally good running on diesel, has anyone got any experience of running such a unit on EHU and is it any good on the electric only setting?
Ivory55
6,017
14,534
North West Norfolk
Since Feb 2012
Hi john, try full timer where he works they fit diesil heaters he might have spares etc or an old one that can be cannibalised.
jonandshell
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
HI Colyn
Not really interested in repairing the old one. We are going to be full timing ourselves on EHU. No point in burning diesel if we are paying for leccy!
DBK
18,029
48,099
Plympton, Devon
PVC, Murvi Morocco
Our dual top has a 1 and 2 KW setting and we have found in the UK even the lowest setting adequate at night.
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
Not had mine serviced since new, 5 years ago. Still whisper quite and faultless.
jonandshell
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Thanks for the heads up DBK.
Is it possible to heat water effectively on leccy or does it take forever?
DBK
18,029
48,099
Plympton, Devon
PVC, Murvi Morocco
I forgot to add the programmable controller is correctly described in that you can program it, but it is a long-winded procedure and once done you won't want to alter it! We just turn the temperature up and down as required. :)
DBK
18,029
48,099
Plympton, Devon
PVC, Murvi Morocco
No, it's quite quick. We've never timed it but if you were in a hurry giving it a blast with the diesel would be the answer. It is equivalent to something like 8Kw. I could do a trial tomorrow if you want - the van is on the drive filled with water for our now cancelled trip to France.
jonandshell
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
No that's OK. Thanks for the offer though!
I was concerned that the heat transfer from the element to the boiler would be slow, given that it is simply inserted into the burner unit vanes!
I will be on the phone tomorrow to a couple of suppliers to get the best price.
It will be an easy install. The new one will bolt straight in, the hole in the furniture is the same for our manual control and the programmable one and all that needs changing is the wiring harness and adding a 240v supply.
jonandshell
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Well, this won't be cheap.
Apparently, Webasto don't allow supply only of the Dualtop because it's too complicated.
Complicated, my arse! It's a bloody heater and boiler, not rocket science!
I am awaiting a price from my local dealer. In the meantime, I have isolated the water supply from the unit and it's cold showers only......
Reactions: DBK
BwB
917
1,170
Suffolk UK
Resting b'twix vans
Since 1990
Presumed you've tried Heatso for supply? They do a lot of that sort of thing and might be able to source for you.
eddie
8,157
41,271
Taunton Somerset
RV
since 1989
Van Bitz were until recently Webasto service agents and we have installed dozens of Dual Top systems
They work exceptionally well on Diesel, and very well on mains
We only gave up the servicing as whilst Webasto are a great company to deal with, and their products well engineered, but some of the companies that install their products want shooting.
This of course leaves the service agents to deal with the customer, and explain that "yes, their trip is cancelled, and no it is not covered under Webasto warranty"
The biggest fault was the failure to clean out the clear swarf from the water tanks when the pipes were fitted, leaving wormlike spirals of translucent polypropylene to work their way around the system and end up converging in the capillaries and valves within the Dualtop
Which then has to be removed and rebuilt.
So excellent kit, when fitted properly
We have loads of spares in stock if you ever need anything
DBK
18,029
48,099
Plympton, Devon
PVC, Murvi Morocco
The control system is quite complicated. Ours started playing up one night so I got the local Webasto agent to look at it. He plugged it in to his laptop and was able to view it's entire life, including error messages etc. But as long as it doesn't require any sort of commissioning I don't see why you can't fit one yourself and if it does you should be able get someone out to do it who has the computer.
Ours has three 12v supplies, one fused at 5 amps the others 10. If replacing the fuses the smallest goes in first.
jonandshell
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Agreed.
Chausson made a pigs ear of the installation of ours.
Wiring too thin, air intakes in the firing line of spray from the nearside front wheel, etc.
I have addressed all the issues on ours so a replacement unit is going to be an easy job.
We will see what that 2 hours is going to cost me!
Jan 28, 2008
10,117
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
as the electric element is 2kw and the deisel burner 8kw its not going to be as powerfull on electric but i doubt it runs at 8kw much anyway. One thing deisel heaters seem to do well is modulate down to the required load
jonandshell
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Well, it is now all on and commissioned, courtesy of M A Autocool of Norwich.
Good efficient service and a very knowledgeable engineer, which is essential for these units.
Leccy performance seems OK and it is nice to know that we aren't using our diesel when we are paying for EHU.
The new control is fairly straightforward too. Although it is a shame the timer can't be used for water heating only in summer mode. We aim to try it on winter mode but setting the cabin temperature really low to see if that works.
We'll see how it goes.
Urs4_2008
266
181
Vestskogen, Norway
Hymer Exsis-I
Since 2009
So did mine until about 6000 hours and more. Then one fan after another needed replacing, then overheating issues. But until then it was, after modifiing the electricals to make it start even If the batteries weren’t fully charged, an excellent unit. The problems with the original wiring design was not Webastos fault but the Dethleffs factory installers / designers. Clever unit
Jul 18, 2009
11,189
17,838
HYMER B644
But you could still install one?
eddie
8,157
41,271
Taunton Somerset
RV
since 1989
what would your cost and availability be to fit an external one be Eddie?
This thread is quite old now,
So wouldn’t want to quote, sorry
