Any suggestions? (1 Viewer)
M1ke
198
118
Huntingdon
Auto Trail Tracker FB
5 years
I want to install some kind of a privacy screen in my motorhome so that the rear can be made into a private bedroom so that the dinette area can be used whilst someone is asleep and not disturbed. I have seen some rear fixed bedrooms have a sliding curtain affair which is more like a stiff fabric which concertinas as it closes. Can you buy these curtains and if so where? Anyone got any other ideas as to what can be used? Not really after sound proofing, just the privacy aspect.
Cheers Mike
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
We have a curtain to separate the fixed bed from the rest of the van. You can get the rail from M/home or caravan shops Mike and can be curved as ours is. :thumb:
M1ke
M1ke
198
118
Huntingdon
5 years
Hi yes I thought of just a curtain but wondered if there was something more solid? Thanks for the suggestion though!
Terry
11,932
9,083
Lincolnshire
Can't remember ;)
Hi Mike you can use normal house curtains (much cheaper)and go for a Swish rail with the small roller bearings:thumb:Get a curtain with the black outlining
terry
chatter
3,689
937
cheshire
5th wheel
We looked at theconcertina door type for our van and decided against them, they take about 3 or 4 inches of space when closed and then there is the track top and bottom to run it that needs fitting, and tracking on the floor would be guaranteed to get all sorts of stuff in it decided to go for a curtain instead
M1ke
M1ke
198
118
Huntingdon
5 years
I think you are right. I have just had a look at the space available and I don't think the concertina type door is going to work for the exact reason you have given. I've had a look on ebay and there is a guy in Peterborough selling a curtain track kit with the fitting for about £13 plus postage, so I might go for that.
GJH
29,450
38,827
None, now sold
2006 to 2022
For our van I used a compression type curtain rod (which fits between two cupboards) and a curtain with rings (designed to slide onto a pole rather than hang from a track). To stop the rod being knocked down I screwed cups (made from walking stick ferrules) into the cupboard frames.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
ours has like a metal curtain track with a 2 piece sliding door and on the bottom there is like a u shaped clip that runs in a slot in the bottom of the door to stop the 2 halves separating.
it just opens into a gap next to the wardobe
you could try those vertical window blinds as they slide to one end when open.
http://www.vertical-blinds-direct.co.uk/
M1ke
M1ke
198
118
Huntingdon
5 years
Great idea, in fact I just found a length of this type of rod in my barn and it seems to fit a treat! The ends have anti slip rubber bungs so I do not need to find 2 walking sticks. :ROFLMAO:
