Any Ideas (1 Viewer)
Nov 26, 2007
148
49
Exeter
c class
Since 2006
Hi,
Just came back from London, and i have a bad drome noise from the front of my Fiat Ducato 2.9 jtd, Any one have any ideas before i take it to a garage ?
Ian
Melian
Nov 26, 2007
148
49
Exeter
c class
Since 2006
Hi,
No it is just a consistenced drome
Jaws
23,836
72,489
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Does it do it at all revs or does it come and go and is worse as you accelerate ?
Jaws
23,836
72,489
Thetford Norfolk
C class, Chieftain
Sorry .. forgot !
Has there been any change in performance at all ?
tonka
10,833
21,532
Cannock, Staffs
A class Burstner 800
Since 2000
Sounds very much like wheel bearing..
Common on Fiats and easy enough to get confirmed...
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Anything regular or with a distinct rhythm is usually mechanical (either that or you've left the radio on at low volume).
My gut feeling is wheel bearing, having had one go in a Fiat Ducato based MH and hearing the drone of doom for some time beforehand.
Before driving it any further, check all the front wheel nuts are all as tight as they should be, without overtightening - they can work loose when wheel bearings get worn out. Our front bearing started to go on the way down to Italy - we continued the holiday but the noise got worse on the way back and on our return we took it straight into the garage to get it replaced under the extended warranty. At regular intervals on the return journey I was having to re-tighten the wheel nuts.
Melian
Nov 26, 2007
148
49
Exeter
c class
Since 2006
Thanks for all reply's, will get it checked out,
Oct 20, 2014
1,345
5,962
Hampshire
Adria Coral 680 SL
Since 2014
Could it possibly be a worn ancillary belt tensioner, does it make that sort of noise? or would that be more whiney?
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
Does it do it when stationary and you rev the engine ??
If not, wheel bearing as said by many.. You can jack up each side and spin the wheels, you WILL hear it !!
