another battery question!
Discussion in 'Tech/Mech General' started by Munchie, Feb 23, 2015.
  1. Munchie
    Munchie Funster Life Member
    Jul 28, 2007
    8,579
    11,799
    Champagnac-La-Riviere
    Ok i am thinking of buying AGM liesure batteries!
    My MPPT solar controller has an AGM setting. So far so good!
    My van 230v controller only has wet or gel
    So which would be the best setting on that for AGM please?
  2. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,863
    1,913
    Warwickshire
    As I understand it, very few motorhomes have a charging system that is optimised for AGM - perhaps some of the latest ones do.
    The required charging regime for AGM is closer to that for flooded than to gel. Gels take much longer to charge, particularly in the absorption stage, so if you set the charger to gel, it may overcook flooded or AGM batteries. The gel setting should also run at a lower voltage than that for flooded.
    Having said that, I think that most AGM batteries require higher voltages than are normally found in flooded charging programmes so the expensive AGM may never get fully charged.
    If you know, or can get, the charging pattern for your charging system (in the manual?) it may be worth talking to the technical department of the manufacturer whose batteries you are considering and ask them for advice.
    • Like Like x 1
  3. Munchie
    Jul 28, 2007
    8,579
    11,799
    If i am on hook up full charge would not be essential and when on solar my controller has an AGM setting.
    I was concerned more that i do not damage the batteries.
