American lights or not?
Discussion in 'American RV's' started by Boo, Jan 30, 2009.
  1. Boo
    Boo Read Only Funster
    Jan 26, 2009
    636
    4
    Cornwall
    Just bought I Winnie and was wondering if I could rewire the amber marker lights/indicators back up to U.S spec as most HGV's have amber sidelights built into the indicators.
    So what do you think?
    Boo
  2. dazzer
    dazzer Read Only Funster
    Jul 30, 2007
    1,698
    99
    In my house
    Not sure on the legalities of it but the fact that they have been changed from USA spec must say something!!
    The other question is why would you want to bother?? If it aint broke....dont fix it:Eeek:
  3. Boo
    Jan 26, 2009
    636
    4
    Cornwall
    Because the conversion was crap.............just led's stuck on the bumper :(
    So I thought I would give the headlights UK sidelights and return the front indicators to U.S spec.
    Boo
  4. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,778
    6,045
    Mansfield,Notts
    Yes you can, but not pass an MOT if you mean they are iluminated all the time and go out when indicating
    you can do as you say but make them work to UK spec:thumb:
    Geo
  5. Tony Santara
    Tony Santara Funster
    Jul 26, 2007
    1,494
    114
    Cheshire (ex Mancunian)
    I rewired my Winnebago marker lights after they were decommisioned
    As long as the amber marker light is incorporated with the indicator light ..that is if you have a double fillament bulb one which lights up the marker light and the other fillament lights up the indicator light ..so you have a amber marker lit and the light goes brighter when you indicate it will be legal . Hope this makes sense
    However you must show 2 white side lights to the front either in your headlight or separately
  6. Boo
    Jan 26, 2009
    636
    4
    Cornwall
    Yes, I plan to put white sidlelights into the outside headlamps (has 2 on each side) and wire another into the indicator lense so it is on but dim, then when I use the turn signal it will be much brighter :)
    Am I right in thinking that an A class is 12 volt and not 24 volt like trucks?
    Boo
  7. Tony Santara
    Jul 26, 2007
    1,494
    114
    yes A class rv's are usualy 12 volt :thumb:
  8. ginge61
    ginge61 Read Only Funster
    Oct 29, 2007
    431
    n/wales
    most us trucks are 12 volt too i think
  9. PeteH
    PeteH Funster
    Nov 22, 2007
    2,213
    2,752
    East Yorkshire
    Lights
    My unit was sold new by Westcroft they wired the side marker lights to indicate in tandem with the front indicators AND to be illuminated when the side/Main Lights are on.
    I assume that they comply?? with the (then) 1993 Regulations and my MOT guy is generally well on the ball and has not failed them in 5 years.
    Hope that is of use??
    PS as far as I am aware Virtually ALL US (truck/bus/R-V's) are 12Volt?
    pete
  10. Boo
    Jan 26, 2009
    636
    4
    Cornwall
    Ok, I've done it :BigGrin:
    Rewired it back to U.S lights but made it so the sidelights stay on when indicating a turn signal, I have also fitted 2 banks of 9 light strips (same as the new Audi sidelights) into the grill as UK sidelights.........looks a treat :thumb:
    ebay number 260358921900
    Boo
