Amateur Radio Antennae (1 Viewer)
tobytenblue
44
26
Somerset
coachbuilt
18 months
Hello All, ::bigsmile:::bigsmile:::bigsmile:
Anyone out there using a 2 meter rig mobile. I'd like to install one in the cab of my CI Carioca but can't see how I'm going to fit an antenna (to essentially plastic bodywork). Not a lot of accessable steel on the wings or bonnet to be able locate one either.
I suspect that someone out there knows how to do it and I look forward to your suggestions.
Thanks,
Brian. ::bigsmile:
tobytenblue
tobytenblue
44
26
Somerset
coachbuilt
18 months
Re handheld
Thanks for that Roger, :Doh:
I want to use it mobile, so h/held not much cop, 5 watts into rubber ducky doesn't do it for me. Apart from which I'll have the steering wheel in my hands!
Brian. :Smile::Smile:
Feb 27, 2011
14,741
76,023
UK
Self Build
Speak to your local metal guy. Get as much sheet steel (1mm) as you can and use sikaflex to glue it to the roof.
You can then attach whatever magmount you want.
Disregard this advice as I am a bit tipsey and will realise the error of my way tomorrow no doubt :ROFLMAO::ROFLMAO::ROFLMAO:
Southampton
522
318
Hampshire
Since 2009
Thanks,
Brian. ::bigsmile:
Try a dipole construction similar to this link, that way you don't need a ground plane. http://www.comrod.com/getfile.php/Datasheets/Norway Antennas - Marine/AV51BI4.pdf
Just a thought. I am in the Defence Comms area and we use these dipole style antennas on all non metallic vehicles, but in the military spectrum.
cbrookson
398
436
Suffolk
Le Voyageur RX9 2012
Since 2001
Try one of the on-glass ones on a side window of the cab:
Link Removed
There is a Watson 2m/70cm one
That is what I've used in the past.
reader
185
73
IO83rk
Feed a coax out of the cab via a grommet under the plastic cover in the cabdoor step and feed to the rear of the van and use a S0239 type mount on the cycle rack. From this take a feed back to the chassis somewhere for a ground plane.
If you havn't got a cycle rack then either a gutter mount or mag mount on the bonnet ( if you use a long aerial may need a kink in it ) but a small dual
bander around 18/24ins should be ok
Other than that a marine type aerial and mount on the body. If you cant get one for around 145MHz a Marine FM band will be close enough through a small atu
tobytenblue
tobytenblue
44
26
Somerset
coachbuilt
18 months
Mobile Antennae
Thanks for the suggestions chaps,
Glueing steel to the roof doesn't appeal at all so that's out the window! :roflmto::roflmto::roflmto:
Have considered the chassis ground plane idea but that seems like too much hassle, I can't be doing with that.
The glass mount seems a better idea, certainly easier, so I've just ordered one. I'll let you know how I get on with it. :thumb:
Thanks.
Brian. ::bigsmile:::bigsmile:::bigsmile:
Dec 23, 2007
4,077
6,547
Wirral
Hobby Van Kenobi
started when I was 11 with my parents-forgot to stop!been real one since 1980!
I have one which has a ground plane that screws to the base of the aerial and then into the base mount.
The one I have is a Wilson Firestik bought from the states. The mobile rally season is about to start one of the dealer may have them. The Northern show is in Blackpool at the Norbreck castle on April 7th.
G8WVW
92
67
Cumbria
C class
Since 1990 on/off
I have a Panoramic 5/8 PMR aerial mounted into the front wing. Very much a compromised as any installation is in a coachbuilt motorhome. Merc Sprinter base vehicle manual states that the vehicle is designed to cope with fields created by 25W VHF/UHF transceiver and never have any problems there. Philips DAB radio however looses lock during every transmission!
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
I have just mounted a CB antenna and a dual band 2m/70cm antenna on the bike rack (well to be honest steveutwg did it)
thick wire from base of antenna to chassis in each case.
CB is great, mini springer with SWR of 1
2m SWR 1.2
70cm don't ask. (5plus)
I thus have a theory that when using a ground plane a lot lower than the antenna base the effectiveness in inversely related to frequency.
If really vital to use 70cm (our local repeater is 70cm) then I think a steel plate glued to the top of the back box and a mag mount will be the answer. I would expect thick enough paint would stop any rusting and anyway you'd need to be 8ft tall to see it.
b1dor
3
Buckinghamshire, UK
Peugeot Boxer conversion
SInce 2011
Mounted a dipole on the rear of the van using one of these as the centre - Broken Link Removed
Both sides are 3/8 thread - so I have a 2m 3/8 thread whip on both sides - Broken Link Removed
Jaws
23,836
72,489
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I simply use a lip mount on the near side of the bonnet
Allows me to use a choice of antenna I have depending on what rig(s) I have in the motorhome at the time, a
decent 7/8th wave or dual band triple 5/8th or even swap it over for a chicken box antenna that it currently has on it
Jaws
23,836
72,489
Thetford Norfolk
C class, Chieftain
why not have 2mtr one side and 70cm on the other. Each will act as the others groundplane.
Intersting idea.. and I guess the 2mtr one might well act as a ground plane ( providing it is not on the same access as the 70cms ) as it is a third harmonic, but methinks visa versa may be a bit of an issue LOL !!
There is also the point that using one to balance the other may well encourage a transmitted harmonic too
b1dor
3
Buckinghamshire, UK
SInce 2011
Using the lower element as a radiator wouldn't be much good as it will effectively be an upside down dipole.
You could use one of these - Broken Link Removed
This is 3/8 thread and dual band - much simpler...
The initial query was for 2M - I also don't use 70cm in the motorhome so 2M only is good with me.
I am in the process of changing my antenna configuration with a pole mounted on the bike rack with the mount on the top of the pole, thus ensuring the radiator is above the roof of the motorhome with the intention of increasing forward tranmission coverage (with the antenna in its current position it's shielded by the motorhome).
b1dor
3
Buckinghamshire, UK
SInce 2011
And on a side note - Only my MPV I have a roof rack with a sheet of galvanised steel peppered with holes in it - all my aerials attach to this - no holes drilled in the vehicle - the whole lot of antennas attached to the sheet of steel inc 80M and top band.
I've got aerials & relays for switching all on the roof rack. Works great - if you've an option to fit a roof rack this will give you loads of scope!
Jaws
23,836
72,489
Thetford Norfolk
C class, Chieftain
Not a lot of good for me.. I would LOVE to get the antennas up there but with a MH the size of ours that would mean they would catch on over head fone lines ( I know all about this.. Nearly lost an 80 stick to a fone line once ( and that was in the car !! LOL !! )
Jaws
23,836
72,489
Thetford Norfolk
C class, Chieftain
Just re read my post about three up !
Bloody auto words !!!
In the post I put:
What it should have read was :
Intersting idea.. and I guess the 2mtr one might well act as a ground plane ( providing it is not on the same AXIS as the 70cms ) as it is a third harmonic, but methinks visa versa may be a bit of an issue LOL !!
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
A few years ago I had a 2/70 aerial mounted on the back hatch of a Nova. I made a plate with a mount on it & used silicone to stick it to the glass. I used a hairpin ground plane mounted on the bracket. The coax came with the aerial & comprised a short thin section connected between a longer length of normal coax & the mount that was intended to pass through a window seal (or in my case the hatch seal). I'd tried a few different aerials on a gutter mount - including the one I finally fitted to the hatch. Nothing worked as well as the one with the hairpin ground plane.
