Alternator Driven Tachometer (1 Viewer)
DJK
63
20
Bury Lancashire
Bessacarr E645
I'm a Newbie
My Fiat 2.9TDi 1999 is without an tachometer anyone every fitted one driven by alternator.
I thought this would be the easiest way of fitting one.
Secondly Anyone recommend a good Sparkie in Bury BL 8 Lancashire conversant with Motorhomes
Badknee
7,408
413,645
notloB
Vantage Neo
Living the dream.
Jeffs auto electrician. 30-36 Bury Old Rd. Bolton. BL2 2BZ
01204 394582.
Fixed my leccy window a treat. (y)
Reactions: DJK
Jan 28, 2008
10,123
18,394
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
i doubt you would find an altrnator driven one now early sprites and midgets had dynamo ones
53,556
150,519
Fitted a taco to a new then 1974 Datsun Cherry, I think it was an induction pick-up from the 12v side of the coil.
Dec 27, 2014
967
3,361
Yes, can be done.
Tiny-Tac do one that has a clamp you put around the injector pipe and has a sensor in it for the pulses.... Trouble is its a digital LED clock, not a sweep gauge. About $70 US.... Available via e-Bay.
11,956
16,571
Alternator drive as an aftermarket fit would be difficult. They pick up a pulse from the alternator windings but are designed to account for the alternator / engine pulley sizes which vary from one manufacturer to the next. The injector type mentioned by Jonkil would be easiest.
23,836
72,603
@DJK This is the link to the Tiny Tac listing on eBay:
www.ebay.co.uk/itm/Diesel-Engine-Tiny-Tach-HOUR-METER-TACHOMETER-w-1-4-Tansducer-MDS-1-4-MDS-1Q-/271251305027?hash=item3f27d67243:g:8ikAAOSwEeFVQTjS
Looks interesting. I have often thought about a tacho on my 2.5TD and this device looks very interesting. If you do fit one let us know how you get on.
Fitted one for someone earlier this year..
I honestly did not think it would work but it did and still does !
I did wonder where it came from .. Chap told me 'a mate gave it to me' and when I searched at the time could not find any info at all
23,836
72,603
Yes mate. It was on an early 80's 2 litre ( might have been a 2.2 ) Ducato lump
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
Most of the accessory rev-counters pick up their signal from the WL terminal on the alternator, this is rectified but unsmoothed DC which has enough AC content to run a tachometer.
Discovery 1's use this system, Discovery 2's use the engine management flywheel speed sensor to get the engine speed signal from, via the ECU.
If you're fitting an accessory electronic tachometer you will need to calibrate it against a known good mechanical tachometer like the Smiths Industries hand-held type.
Diesel pulse tacho's are quite good and no electrics other than the 12V supply.
Lots of other ways of doing it, we have fitted magnetic pickups to flywheel housings, getting the signal from the flywheel starter ring gear teeth going past the end of the magnetic pickup, have also used timing gears and even a toothed belt cog to get speed signals.
Peter
DJK
DJK
63
20
Bury Lancashire
Bessacarr E645
I'm a Newbie
Thanks for the replies Folks, with exception to a couple Would a TDI (Turbo Diesel Injection) have a distributor Lol
Anyone any idea on any cost please
43,357
49,636
Seriously, Yes it does........
Its called a mechanical high pressure injection pump.
It DISTRIBUTES the incoming fuel to each injector in turn.....hence, a distributor.
DJK
DJK
63
20
Bury Lancashire
Bessacarr E645
I'm a Newbie
Well Pappajohn
You have just learned me something I've been connected with Lorries, engines and FLT's all my working life and I'm in my 70'th year now and never have I heard an diesel injector pump be called a distributer I've heard it called many many names Not printable on this page when it won't bleed but never a distributer.
The pinto engine in my Sports Cars got one but that's a 2 litre "Petrol"
Good Night my friend I'm now going to bed smiling
DJK
DJK
63
20
Bury Lancashire
Bessacarr E645
I'm a Newbie
Badknee have you got a VW MH if so is that you on Google parked outside his place
DJK
DJK
63
20
Bury Lancashire
Bessacarr E645
I'm a Newbie
Badknee is this your VW MH parked outside
Badknee
7,408
413,645
notloB
Vantage Neo
Living the dream.
No it's not me, Google hadn't been invented when I had my VW type 2 bay window.
Peter A Forbes
270
184
Mercedes 614D
Well Pappajohn
The CAV DPA pump is a distributor pump, so called because the fuel distribution out the the injectors is set radially around the pump rotor housing. This is different to in-line injection pumps where there are individual elements for each cylinder. DPA pumps only have one pumping element.
Bosch have something similar, as do Kikidiesel and Bosch licencees worldwide.
DPA I always took to mean "Distributor Pump Assembly".
Peter
DJK
DJK
63
20
Bury Lancashire
Bessacarr E645
I'm a Newbie
Boy O Boy are we getting serious.
I think it's time for this post to end.
