TerryL
I have decided to go the same way , i have ordered 3 x 130 AH batteries and 1 x Sterling BBW1260.
P.S of the 3 batteries 1 will be replacing the existing leisure battery , then the other two will be additional leisure batteries , Am i correct in thinking that i do not have to change the Cab battery as well ?? ,, with it not being new sure it will not effect the new leisure bank ??
Are you sure you've got room for 3 batteries? I'd be struggling to find space for the third, and I think your van is very similar to mine. They'll need to be properly fitted, vented and wired up.
The battery mate I referred to in my original reply is a gizmo that keeps your cab battery topped up (if needed) from the leisure batteries if/when there is spare juice. Not expensive and probably worth adding to what you are planning. You don't need to worry about the cab battery.
