alko rear suspension
Discussion in 'Swift Motorhomes' started by stewrty, Aug 16, 2011.
  1. stewrty
    stewrty Read Only Funster
    Oct 24, 2010
    14
    help i cant get my rear wheel off the rear suspension seems to be seized any tips on trying to free it thanks
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    there are a number of posts on this I believe. The Alco rear axle/suspension needs greasing approx every 6 months. I hope you are able to free it as replacement is expensive. Dave Newell is the man to ask, he is a trade member here. Good luck
  3. stewrty
    Oct 24, 2010
    14
    thanks
    thanks for the name how can i contact him cheers
  4. hilldweller
    Dec 5, 2008
    27,771
    26,862
    Macclesfield
    You mean the wheel nuts are seized ?
  5. stewrty
    Oct 24, 2010
    14
    rear suspension
    no the rear suspension arm wont let the wheel come down low enogh to come off so must be seized cheers
  6. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,494
    894
    South Glos
    What van have you got?
    It is very difficult to get the rear wheels off of my van (lunar Roadstar 786) because the fairings the converter added to the body fowl the wheel when trying to remove it.
    Are you sure its not just a design feature of the conversion.
    Lunarman
    • Like it Like it x 1
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,268
    17,931
    YO11 2BD
    i think you'd know if it was seized.....the 'ride' would be unbearably harsh !
    reckon its as lunarman says....poor design. :Sad:
  8. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,668
    7,793
    england
    if you need to grease it jack both wheel's off the ground and you will find 2 grease nipple's on the axle one each side,pump as much grease as it needs untill you cannot get any more in,do every six month's:thumb:
  9. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,668
    7,793
    england
    another point.
    never try and strip the suspension down if you aint sure what you are doing as it is a pre-loaded torsion bar setup.:thumb:
  10. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,632
    3,466
    Telford, Shropshire
    If it is siezed (and I have seen them sieze up) then you may be lucky and it can be freed off, takes time, serious heat and lots of wd40 and grease. If it won't free off then the axle is scrap and will need replacing as a complete assembly.
    D.
  11. hilldweller
    Dec 5, 2008
    27,771
    26,862
    Macclesfield
    Disgraceful.
    The designer should be shot.
    I've got a distant memory of something similar with VWs long ago, tales of cutting open a tube to do a repair.
  12. Wildman
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    It may be something as simple as jacking the body off of the axle to get the clearance. you don't say where you are but many trade members here. to find a particular member look in the members list (under community+)
  13. stewrty
    Oct 24, 2010
    14
    suspension seized
    yes it is defenetly seized sold in the up position there must me a trick in freeing it big hammer and wd 40 cant get greese in as torsion bars seem to be covering the holes as have taken nipples of to get wd 40 in van is 21 years old has it ever been greesed in aberdeen by the way cheers:cry:
  14. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    you may be able to get a scissor jack in between the trailing arm and the chassis but if its been seized a while you may just have to bite the bullet and get a new one.
    i wouldn't trust a second hand one as you just don't know what its done or how its been serviced ( if at all ).
  15. stewrty
    Oct 24, 2010
    14
    seized suspension
    thanks i would try the jack idea but very flimzy body work around there cant aford a new one i will try any thing its an old swft kon tiki but a good van for its age cheers
  16. aba
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    if you can remove the shock absorber you may be able to jack it down on the shock absorber mounting points but be very careful just how much pressure you put on them if you can get it to move a little bit even a couple of mm then you are going to have to then transfer the weight of the van back onto the wheel to move it back the other way.
    if you have to apply heat to the axle tube shield the van floor with aluminium above where you are warming and have a fire extinguisher handy as motorhomes burn very quickly.
  17. stewrty
    Oct 24, 2010
    14
    seized suspension
    thanks for that idea i will give it a try a let you know thanks again:thumb:
  18. stewrty
    Oct 24, 2010
    14
    seized suspension
    well i have taken off the shock hoping to atempt to jack the torsion bar arm down but the top of the shock is just a bolt hole any ideas cheers:cry:
