Alko Chassis Corrosion
Discussion in 'Tech/Mech General' started by Xabia, May 26, 2015.
  1. Xabia
    Xabia Funster
    Jan 20, 2011
    729
    431
    Rural Nottinghamshire and Spain
    The Alko chassis on my 2007 chassis is showing signs of corrosion, mainly where a towbar was originally fitted, now removed.
    Advice needed please about how to deal with it. Do I just rub the rust down and coat with something like Hammerite, or do I need to use some special paint?
    Mike
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,710
    17,328
    YO11 2BD
    You can buy galvanising spray at most electrical wholesalers....and other outlets I'm sure.
    Not as effective as hot dip galvanising but bettet than paint in my opinion.
    Maybe need a couple of coats to cover fully but dries in half an hour.
    Rub down first but not between coats...just recoat when the first is just touch dry or tacky.
    It's used for treating cable installation tray after cutting to length.
    • Like Like x 3
  3. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,107
    14,921
    Leeds the one up North
    Yes as John said a cold galv spray
    Just rub all the loose off first.
    Galvanising is a sacrificial coating to save the steel so just keep on top of it (y)
    • Like Like x 1
  4. Lindsay
    Lindsay Read Only Funster
    Jun 29, 2014
    16
    10
    Ayton, Scottish Borders
    Try a web search for a brush on paint called Galvafroid. That's the stuff! (y)
    • Like Like x 5
  5. Techno
    Jul 28, 2010
    14,107
    14,921
    Also available as spray
    • Like Like x 1
  6. pappajohn
    Aug 26, 2007
    29,710
    17,328
    YO11 2BD
    Brush will get a thicker coat but spray will get into inaccessible corners.
    Any bits missed will just rust even more spreading under the good galvanised finish.
    Once the original galvanising is compromised it will be a constant maintenance job.
    • Like Like x 1
  7. Techno
    Jul 28, 2010
    14,107
    14,921
    Trouble with brush on galv is all the zinc sinks to the bottom of the tin and no matter how much stirring the mix is inconsistent
    Multiple costs of spray are much better IMHO (y)
  8. Xabia
    Xabia Funster
    Jan 20, 2011
    729
    431
    Thanks to everyone for the very useful advice, now I know what to do! (y)
    Mike
  9. voyagerstan
    voyagerstan Read Only Funster
    Aug 7, 2011
    323
    211
    torquay sometimes
    :cool:
    IUse some rust treatment first and then galv STAN
  10. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    There was me thinking ALKO chassis meant aluminium :(
