Alde when mobile (3 Viewers)
Brian and Jo
3,002
6,447
oswestry,shropshire
A-Class N+B Arto 88F
Been motorhoming for 15yrs.had an American RV for 7yrs,Now got a Niesmann Bischoff Arto 88F
hey guys,can you just tell me please is it ok to run the Alde heating on gas when mobile?
Brian & Jo
Brian and Jo
Brian and Jo
3,002
6,447
oswestry,shropshire
Wow thanks Brian ,2 minutes for a reply and people ask is MHF good value for money:rolleyes: there is only one answer to that YES(y)
Brian & Jo
icantremember
8,336
17,556
Near to Watton in Norfolk
Hymer T-SL668
since 2005
We also have the Alde heat exchanger which will allow us to run the habitation heating off the engine but I haven't tried that so far .... waiting for the colder weather which seems to be on the way now!
19,377
30,376
It works, gives hot water in the tank and Heating on the thermostat.
icantremember
8,336
17,556
Hymer T-SL668
since 2005
I reckon you will soon;)Brrr.
Certainly feels like you're right there it's bl$%y freezing here in Kent today .... sitting in moho with heating on while waiting for family to arrive for lunch.:rolleyes:
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Don't have a heat exchanger but the ordinary Alde runs while we drive.
In the past we have just left it switched on 24/7 but we do have the Truma gas crash thingy fitted.
Richard.
Lanerboy
1,363
2,206
midlands
Carthago 4.9 superior
My Rapido has the aldi wet heating how do I know if I have this heat exchanger fitted as I was told to run it on gas whilst on the go
May 8, 2016
1,685
81,111
silver coast, portugal
C Class: Low profile
Boatie for 20 years
Our Chausson manual says not, but that is probably because they were too tight to fit an anti-collision gas shut off (Truma thingy) and instead fitted a very decent diesel Ebersprecher which is fine for use when travelling and extremely economical.
Theonlysue
6,104
7,383
As Executive 50th an
Not long enough!
Somewhere there will be a switch to switch it on. Might be by the steering wheel and another by the alde panel.
Then on the Aldi panel you want pump on continuous. If you set it to thermo it will be controlled by the thermostat which if it's cold you don't want.
Aug 19, 2014
1,855
5,568
Cliftonville
A Class Burstner
Since 2014
Go to the Aldi website.... they show all their supermarket locations.....:D2
19,377
30,376
If you have something like this in a locker or underfloor,
You have a heat exchanger, it may have a manual valve to isolate it in the summer, it may have a solenoid which will have a switch, it may have nothing in which case the radiators might get warm all by themselves in the summer.
Of course you might not have on as they were usually optional.
bigtwin
5,246
9,952
Derby
Concorde
Somewhere there will be a switch to switch it on. Might be by the steering wheel and another by the alde panel..
The switch is only required if you want to pre-heat the engine from the residual heat available from the 'central heating'.
You leave the switch off if you want to heat the habitation area using engine heat - you need only to switch the normal Alde control panel to heating but without selecting a heat source (gas/electric).
At least that's how it works on my 2006 system.
Ian
19,377
30,376
Ian
Correct, as long as the heat exchanger is available, ours isolates with a valve but I believe some have a switched solenoid but whatever you don't need the auxiliary pump on as that is for engine heating as you say.
bigtwin
5,246
9,952
Derby
Concorde
Correct, as long as the heat exchanger is available, ours isolates with a valve ......
As does ours but I've never yet had the need to isolate it.
Whether or not I take heat from the engine is determined by how I've set the control panel.
Ian
19,377
30,376
Ian
if i don"t isolate it every now and again I will think "wow its B warm in here" and I will find that there is heat coming out of the radiators, not good when its 28 outside:LOL:
