Alde heating fitting the battery backup (1 Viewer)
FM02MZO
216
36
Castle Donington
Coach Built
30 years caravan, 2 year motorhome
We have recently bought a new Bessacarr 584 which is fitted with Alde heating, and we have got fed up with setting the clock etc., in the control panel (Alde 3010). So I have ordered the battery backup for it, which I intend to fit at the weekend (providing it arrives !!!)
Looking at the control panel, I cannot see any screws, so I presume the front just flips off, is this correct ? And does anyone have any tips on doing the job.
FM02MZO
FM02MZO
216
36
Castle Donington
Coach Built
you can find all the instruction manuals here :-
http://www.alde.co.uk/manuals.php :thumb:
Thanks for the links, the relevant manuals were actually supplied with the motorhome, but they do not tell you what I want to know, i.e. that is how to remove the front cover from the control panel.
Rapide561
471
167
Leeds and Lake Garda
Alde
I cant help with your query but if you phone Alde in Wellingborough they are ace! I am sure they will help you.
Alde - 01933 677765
I'd be interested how your battery back up goes - it really annoys me and it a let down about the Alde system.
We fitted the load monitor though - that's fab!
Russell
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
if you have the older display with the 5 buttons on the right
the rear cover just clips off provided you can gain access to it.
and looking at it square on from the rear the battery back up pins are in the top left corner.
don't know how the front comes off as ours is mounted through the side of the wardrobe and I can access it from there.
incidentally ours had a plug on the battery back up pins turned out it was the remote temperature sensor that had been plugged on the wrong place.
hope this helps.
198
60
norwich
swift escape 640
since 2009
you are correct. for the new digital panel it just pops off , bottom first. screws are behind,very tight fit. and I agree backup is a must, otherwise a real pain. must put order in for mine.
FM02MZO
FM02MZO
216
36
Castle Donington
Coach Built
Many thanks for the above. that is the info I am looking for.
