Alarm false triggering (1 Viewer)
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
The Autowatch 695 alarm went off on our new Burstner this morning just before 7am. Also went off this evening at 9pm. When I went in after the latest event I found a daddy long legs sitting on the ceiling. Is there any chance this may have set off the PIR. I thought these react to a moving warm body. Needless to say I have now turned off the internal sensors and will be keeping the keys close at hand. There is apparently no way of finding out what caused the alarm. Unless of course someone on here knows different!
Nov 3, 2013
3,170
9,384
Portugal
Fiat Ducato Auto Wildax
C/van since '73 .M/h.2009
Hi.
Had an estate car once,if it was very windy,the wind would set it off,it was suggested that i close the external air inlets on the heater system. This seemed to work,but i moved it into the shelter of a hedge as well.
Hope this may help.
Tea Bag
eddie
8,157
41,270
Taunton Somerset
RV
since 1989
In this day and age there must be some basic diagnostic information available even on a car alarm
Speak to your installer again and persevere
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
Ive heard of spiders activating alarms by getting into the PIR unit and crossing the sensor so I suppose it's possible the daddy long leg could trigger it.
Other thing to consider is if the activation time relates to say, the central heating in the house coming on via wireless thermostat or timer.
I once had a problem with a caravan alarm, the PIR was actually defective and would just trigger at random times. During the course of trying to fathom the problem, I contacted Sergant technical support, who told me the PIR unit should be placed at least 1 meter away from the Phantom tracker fitted with the alarm system and that less than this distance the tracker monitoring system could cause interference with the PIR causing random triggers. Unfortunately it seems a lot of manufacturers don't adhere to this distance. It also became apparent they fit the tracker in the same location in all of the caravans fitted with Phantom tracker, not ideal so I moved mine to an alternative hidden area about 2 mtrs away.
In the end it was found to be a duff PIR and was replaced under warranty and never had a problem after that.
I know this is a bit long winded but may be worth considering all possibilities as opposed to disarming the interior sensors.
Wickolad
490
542
Wickersley
Hi, found this link that may help, it relates to Autowatch diagnostic codes and how to access them.
http://vehiclesecurity.co.nz/blog/autowatch-diagnostic-codes
Hope this helps
Lance
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
Have you looked for evidence of a possible rodent visitor!?....
Clickem
1,034
1,073
Northumberland
None
7 years
We recently had a couple of false alarms caused by a proximity switch on a locker door. The part attached to the opening door had got knocked, and with slotted holes had moved too far away from the fixed part, when the door was closed
paulmold
892
302
North Wales
7 year (25yrs a tugger)
Our Cobra alarm went off one night last week. Couldn't find anything wrong until a tiny moth flew in front of my face. Moth disposed of, hasn't happened since so I assume that was the cause. The Cobra isn't tilt attivated, as my previous Sigma was, so isn't affected by wind rocking the van, the Sigma always went off in strong wind.
