Air?? (1 Viewer)
crabman
336
188
Anglesey Wales
just looking
newbie
check my tyres and spare pressure at the garage on a regular bases, if the crap was to hit the fan I would call out the RAC,
Jeff and terri
Jeff and terri
173
101
Suffolk
Ford transit twin wheel
3 years
Yea but do you really want to wait at a garage while people check all there tyres ?? My local tesco always has a line of cars waiting to use the air pump
TheBig1
17,630
43,279
be prepared to wait a long time to reach 4.5-5 bar
Jeff and terri
Jeff and terri
173
101
Suffolk
3 years
Lol I can wait I'm in a motorhome:)
The YouTube video shows it blowing a tyre from flat to 35psi in 4 minutes and you set the pressure you want and it cuts of once reached . Just time to put the kettle on :)
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
5 years, feel free to ask me about the Carado!!
Just wondering do you use a foot pump , analog, or digital air compressor for blowing your tyres up on your motorhome??
I just decided to buy this one ..
https://www.ebay.co.uk/itm/302141984086
I think it's neat and tidy
I had one but it failed to pump my rear tyres up to the specified 5.5 bar, it would only go up to 4 bar. I bought a big manual pump and a mains compressor, tyre pumps is no longer an area I skimp on !
Oct 7, 2013
5,894
36,913
South Wales
Swift Escape Compact
Since 1988
I use a high pressure cycle "track" hand pump with foot stirrups. £30 from
Halfords.
It not only inflates the tyres but allows me to pump up the air suspension in order to avoid grounding when leaving our drive.
70 psi to clear the driveway then drop to 45-50 for running.(y)
Steve N Tracy
1,235
3,728
Southampton
4 Years
I have one of those 20 mins to reach 65 psi per tyre from 50 psi, on the third one it was so hot the display died and never recovered. Fine for cars no good for van tyre pessures.:cool:
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
had one and it was fine for a while but then the digital pressure gauge failed, and so the pump bit was permanently 'off'. I have replaced it with a similar but cheaper one with an analogue gauge and that seems fine. It is quite slow to raise the pressure though.
On my Discovery I carry a 2 cylinder electric pump which is much faster but needs direct connection to the battery as its current requirements are too high for a lighter socket.
Minxy
32,656
66,560
E Yorks
Carthago Compactline
You'll find that many of the air pumps on garage forecourts don't go up to a high enough pressure for MHs, we needed to top up our tyres at one point and it took ages to find on that was suitable.
Many of the ones you can buy also don't have the grunt to go high enough either. :(
Lenny HB
53,431
150,019
On the coast in West Sussex
Hymer B678 DL
Also tyres will be hot, if I top up the car at a garage I over pressurise them and when I get home I let the tyres cool down for at least 30min then set the correct pressure.
Tweedie
211
150
Northants
Bailey Autograph 740
1 year (getting a bit experienced now)
As Minxy said we also have found that a lot of garages pumps do not go high enough, also frequently not working or else access to the pump is too awkward. Funny enough was just checking past threads on best type to buy for this years travels.
golly
2,006
69,617
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
I have had three inflators in the past including the one you have bought, all worked to a certain extent, but non satisfactory. In the end bit the bullet and got one of these, not cheap but needs must.
http://www.ebay.co.uk/itm/Ring-RAC9...re-Inflator-Air-Compressor-Pump-/280521656913
Shop around for best price
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
I looked at a few inflators but settled on a Ring RAC900. It will easily cope with the 5.5 bar, + 80psi pressures needed in your tyres.
The problem with lower capacity inflators is that by the time your tyres are up to pressure ( if it will get that high) , your battery is flat!
Oops, spent too long typing, ours is like the pic above..
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
Most of them only go up to 5 bar, although I did find one in Portugal that did 5.5 comfortably, but the Portuguese garage owner was telling me not to fill my rears to that.......when I did he crossed the road and hid in a shop :)
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
Definitely worth having your own pressure guage as well, many of the garage ones are way out! Plus you can check when the tyres are cool and I don't remember having my own pump that was properly accurate either.
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
D
deleted-member02
I also opted for a 240v pump, so much more oomph than most 12v models.
This one comfortably inflates to 80psi, I've had mine a few years, it gets used often and still sounds good.
Broken Link Removed
Gellyneck
9,235
18,210
Scotland
More than toes wet now!
Anyone bought and tried one of these from Lidl?
PARKSIDE® 1100W Compressor
Still some left in stores from last week's offers.
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
