Is it on a std Fiat chassis or is it on the AlKo chassis? Auxilliary air suspension can certainly help with on road stability but its not likely to make much difference to rocking and rolling on site. We fit the Dunlop system and the most popular option for the filling point is a single gauge which both side's air lines connect to via a simple tap in each line. The top of the range option is a built in 12V heavy duty compressor with control panel on the dashboard but it is a painfully expensive option.
D.
With respect Dave I thought the on board compressor option with control panel was good value from yourselves. The free trip out and recommendation to a great site nearby were just icing on the cake.
ps: the Funster discount you give took the pain out of the "option".
Will Air make the same differences to a brand new vehicle or are the benefits mainly on older vehicle
The benefit to a new vehicle is huge. Do to one where the suspension components are used the benefit must surely be even bigger.If I may jump in on this one. Will Air make the same differences to a brand new vehicle or are the benefits mainly on older vehicle that have well used suspensions?
The benefits sound really good, but would it be worth waiting or getting done sooner rather than later. Vehicle is only a month old.
YES it will make a difference, you've got a longish MH (Sunlight A72) so you will certainly notice the better handling, ride etc - if you wait, once you DO get it you'll kick yourself for not doing it sooner!If I may jump in on this one. Will Air make the same differences to a brand new vehicle or are the benefits mainly on older vehicle that have well used suspensions?
I had mine fitted to a three month old Frankia Platin Plus and really pleased with. I did not have the onboard compressor just the twin 8inch bellows to the rear axle. I use a standard cigar lighter compressor to raise the pressure.
Popeye, may I ask where you had yours fitted and which type please?
PM sent old mate......
The 12v compressors used; are they special or whould the tyre inflator that came with the MH work?
@ dave newell lvs I have just emailed you reference fitting of the Dunlop air assist system after reading this post, thanks folk's.
Email replied to, thanks.Email replied to asking for more details.
D.
