Air Ride revisited...
Discussion in 'American RV's' started by American Dream, Mar 20, 2010.
  1. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Took the old girl for a spin today.
    Well overjoyed at the stability and increased ride height from using the air units.
    Running at 40psi at the moment which seems to give a very reasonable ride.
    What pressure do you run yours at?
  2. Autoquest
    Autoquest Read Only Funster
    Oct 13, 2008
    391
    36
    Small EU backwater
    one bar :Blush: (I've only got a little one...) :Sad:
  3. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Wish I had some times too....:Doh:
    1 bar = 14.5037738 pounds per square inch. Good old Google.
  4. MAUBRI
    MAUBRI Funster
    Aug 9, 2008
    196
    4
    Lanner - Cornwall
    Mine are at 60psi which are Firestone Ride Rite, thats what the chappie before me had them at. The majic book suggests " 50lbs of load for each P.S.I. of inflation pressure per pair e.g. 50 p.s.i. will support a load of 2500lbs per pair of springs.FOR BEST RIDE use only enough air pressure in the helper spring to level the vehicle when viewed from the side. TO PREVENT POSSIBLE DAMAGE TO THE AIR SPRING MAINTAIN A MINIMUM OF 10PSI AT ALL TIMES and never go above 100psi"
    Brian
  5. dragabed
    dragabed Read Only Funster
    Apr 15, 2009
    63
    http://www.motorhomefun.co.uk/american-rv/21836-air-ride-revisited.html#post264769
    tried 40 too hard now on 35 much better(hymer564)
  6. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    I'm staying at 40psi I think.
    Good balance between road ride and body roll...:thumb:
    Really depends on total vehicle weight,body height and personal preference it seems.
  7. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,835
    3,339
    Eastbourne East Sussex
    Mine on 40psi seems OK:thumb:
  8. billinjah
    billinjah Read Only Funster
    Apr 20, 2010
    7
    have my ride rites at 45 psi might try a little more to level her out the handling improved greatly when i went from 25 to 45.
  9. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Settled at 40psi for mine at the moment as it gives a nice balance between ride quality and body roll control.....
    I cannot believe the difference it's made...:Cool:
  10. 656
    656 Read Only Funster
    Jul 30, 2007
    1,150
    291
    The universe
    35psi here!
  11. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,232
    16,834
    Liverpool.
    John Deere chassis with rear ride rites,run at 60 PSI to compensate for extra fuel tank.Rides perfic.:thumb:
  12. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    I'd never checked ours :Blush: but did recently and found out exactly why Winne wandered a bit, near side approx 15psi, offside BURST! Some idiot had replaced the offside but not fitted the top and bottom protectors so supprise supprise the top of the spring had put a hole in it:Angry:
    Any road, replaced and currently running 55PSI (60 seemed a tad hard when driving)and what a difference, sooooo much nicer to drive. I got keen and got the remote inflation pipes off Duncan at Newark, can't be doing with all that crawling around, and will now be checking regular, book says once a month at least but I guess the logical is to check when doing the tyres:thumb:
  13. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,941
    Does fitting air-ride automatically up-rate the max permitted weight?
    Graham
  14. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    I wouldn't have thought so Graham....So many other things to take into account like tyre loading, chassis etc.Someone might just come along and have more info on this.:thumb:
    It certainly did the job I fitted it to do.
    That was to control body roll and raise the rear end of the RV to a better ride height where the original springs has become a little lazy over the years giving reduced ground clearance.
    Certainly compensation for different loadings is possible.
    Steve.
