air pump (1 Viewer)
lugnutt
1,190
466
wednesbury.westmidlands
autotrail apache
10 years
hi all...my air pump has ceased up. this is to pump air through the intake and through the exhaust. has anyone else had this problem
dave:cry:
American Dream
156
Lincoln
dave:cry:
Is this a petrol or diesel Dave?
Sounds more like a supercharger. You mentioned a Belt drive in the other thread.
Good Luck with the MOT.:thumb:
johng
587
Kent/Sussex UK
1984 C ClassGMC
Hi Dave, Steve
Dave if you have a chevrolet etrol engine :
sounds like the fored air into exhaust emmision system.. pump is the top most belt driven device on chevy engine..
forgotten it's acronym..
Supposed to help burn emmisions out of manifolds by adding oxygen, in reality just dilutes the emmisions. Thinking of removing mine , the problem is, it is the point of belt adjustment for that belt.. Would suggest you do the same Dave but we need to be able to keep that belt tight, it either does waterpump or alternator, not sure
John
American Dream
156
Lincoln
Ah Right I got you now.
Some form of emission control:thumb:
Does this restrict inlet or exhaust flow if it is not turning?
johng
587
Kent/Sussex UK
1984 C ClassGMC
hi Steve.. no not as such..
what it does though is restrict airflow in the exhaust ports all the time :)
the manifold nozzels should be ground away and holes plugged, to get a nice airflow back out of exhaust and a healthy power increase AFAIK ... been reading a good tuning book mainly based on chevy engines..
also, the pump has to sap some power..
johng
587
Kent/Sussex UK
1984 C ClassGMC
nah ;)
maybe later
I cant get my manifolds off , silly bolts with shallow heads and a lot of rust.. think i will concentrate on carb rebuild, first, then when shes running, empty the ever filling black tank::bigsmile:
whats news on yout MoT
American Dream
156
Lincoln
nah ;)
maybe later
Ouch Don't mention The Black Tank.:Doh:
Yep It passed.Just needs a new exhaust Box some time as it's getting a bit ropey.
How's the carb coming along?
johng
587
Kent/Sussex UK
1984 C ClassGMC
just payed a guy in florida.. carb should begin an interesting journey to be at this farm in about 2 weeks, dont ask :Smile:
In the meantime, new rad to be fitted, cooling pipes altered, may drain the autobox, some damp in the overhead, a damn good clean of exterior, plus a million other jobs. got dad coming down over easter from Newcastle, so will put him to use for a day..
well done for mot, i got mine in Jan..
johng
587
Kent/Sussex UK
1984 C ClassGMC
I was quite lucky with the rad.. they are only about ÂŁ135 new delivered, but banbury motor spares had a virtually new one for 65ÂŁ delivered, got it last week, looks perfect, may only have been on previous vehicle for a few mothns.
lugnutt
lugnutt
1,190
466
autotrail apache
10 years
hi all...
update the bongo passed the mot.
motorhome is still in dock.
been on to west midlands American motors and they say take it of as not needed in uk.mine is a ford but some cheveys have to one each side.so the fan belt will be different.the garage is trying to free it but if not going to bypass it
dave
American Dream
156
Lincoln
hi all...
dave
Excellent News Dave.:thumb:
Hope you can sort the RV.
Is it a standard "v" belt?
I had to re-instate my belt arrangement after someone had messed it all up.
Just measured each individual belt run (allowing for the ability to adjust the tension) and went down to the local Motor factors.
Bought 2 of each.
lugnutt
lugnutt
1,190
466
autotrail apache
10 years
i had a belt from linda witch seemed to small but if not running the air pump might just be ok maybe the standard belt is for none air pump models
lugnutt
lugnutt
1,190
466
autotrail apache
10 years
just beesn on phone to dave evans my mechanic he has taken it of and unseized the pump put it back on and while backing out of gararge it siezed up again he is not a happy chappy:cry:
johng
587
Kent/Sussex UK
1984 C ClassGMC
:) just found out on my engine, the air pump and alternator share a belt BUT it's the alternator that adjusts,, so, I can remove the airpump from the loop, and get a smaller (70cm) belt that just does alternator.::bigsmile:
