Air bag warning light help please
Discussion in 'Motorhome Chat' started by SandJ, Dec 7, 2013.
  1. SandJ
    SandJ Funster
    Sep 14, 2007
    1,614
    560
    North Yorks
    Fiat x250 2011
    Passenger airbag warning light staying on any ideas please?
    TIA
  2. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,800
    3,346
    East london
    I'm sure there's a previous thread on a fiat airbag warning light..
    I do know though that these are actually restraint system warning lights and can be activated by faulty connections to the front seat belt connectors.. Or occupancy sensors.
  3. SandJ
    SandJ Funster
    Sep 14, 2007
    1,614
    560
    North Yorks
    Thanks I have done a search but nothing found hence the request:thumb:
  4. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,816
    1,031
    Cark, Cumbria
    Look for wiring connections or damaged wires under the seat.
    make sure the ignition is off or it can activate the airbag.
    has it got a switch to dissable the passenger airbag? some do, some don't.
  5. SandJ
    SandJ Funster
    Sep 14, 2007
    1,614
    560
    North Yorks
    Can't find any loose wires and according to handbook there does not seem to be a way of turning it off.
    Looks like I need to book it into Fiat :cry:
  6. Daedalus
    Daedalus Funster
    Nov 3, 2013
    77
    143
    North Cumbria
    Don't know whether it's the same fault, but this happened on my car - turned out to be the air bag firing squib had gone duff - apparently it's very easy for a competent garage, with the relevant diagnostic equipment, to check and inform you exactly what is wrong.
    Shouldn't cost a fortune either.
    HTH
    Daedalus
  7. SandJ
    SandJ Funster
    Sep 14, 2007
    1,614
    560
    North Yorks
    Sorted
    Couldn't find it in manual but may have missed it
    As to why it happened?
    Incase someone else needs fix then
    Mode on right of dash press mode then up button till Bag P then mode
    up till On is displayed then Mode
    Conf
    Up till on is displayed then Mode
    It should display
    Bag P
    On
    Sorted:thumb:
    • Like it Like it x 2
  8. busby
    busby Funster
    Aug 18, 2011
    3,720
    3,495
    derbys
    God that sounds to high tech for me. BUSBY:Laughing:
    • Like it Like it x 1
  9. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,644
    3,477
    Telford, Shropshire
    Do you actually have a passenger air bag? If so then what has happened by some means or other is it has been switched off ( a setting to allow a child seat to be used in safety on the front passenger seat). When its switched off there is a warning light to alert the driver to this fact. The de-activation of the passenger seat airbag has for a long time been done via a key switch, often located in the glove box.
    D.
  10. SandJ
    SandJ Funster
    Sep 14, 2007
    1,614
    560
    North Yorks
    Dave as to why it came on then that is a mystery :Eeek:
    It does have a passenger airbag and yes it was that warning light but if you see my earlier post it is turned off/on by the mode button see. Photo attached
    :thumb:
  11. dave newell lvs
    Oct 31, 2008
    2,644
    3,477
    Telford, Shropshire
    I read your post and understood it, I was simply trying to clarify for others that on many vehicles disarming the passenger airbag in order to use a child seat was done via a key switch often located in the glove box, I wasn't trying to say yours should be like this at all. I should have been clearer in my explanation:Wink:.
    D.
  12. bobandjanie
    bobandjanie Funster Life Member
    Apr 28, 2008
    4,545
    2,665
    UK / Spain
    Glad its sorted Steve, something else I have to remember, :Wink: mind the mode buttons when spring cleaning. :Laughing: Bob.
