- Apr 19, 2019
- 2,292
- 4,851
- Carado T339
- 5 years
I'm a bit confused because there isn't any biological treatment in a cess pit and therefore the bleach can't do any harm. Are you sure it wasnt a septic tank?"The Baby" is now the wrong side of 30, so this was a while back, so terry nappies would have been the "in thing" in the early 1990's
The houses were all old, (parents house was originally 1700's), even the 'new' house next door would have been mid Victorian.
I think the original cess pit would have been fed using slate lined culverts deliberately designed not to be waterproof leading to a single pit shared between the houses, filled with beach pebbles.
It may have been dry stone walled, again designed to slowly leak.
In the 30 years that my parents lived there as far as I remember this was never pumped out or cleaned.
I guess everyone knew not to use powerful chemicals or bleach down the loo.
Remember before the late 70's, most houses did not have a washing machine, that is what the laundry or laundrette was for. (I bought my first one in about 1994)
When the cess pit was killed off, there was no easy way to restart it, as by this time an area of the field below the houses had turned into a stinking swamp.
The only solution was to dig it all out
(They had to come to legal agreement with the farmer, lay a metal track across the field for the for the digger and multiple lorry loads of earth and pebbles and rock out,)
Then install 4 x plastic septic tanks side by side but far enough apart (The trench was vast, big swimming pool size), then lay 4 x plastic sewer lines across the field and plumb into 4 x houses.
In the meantime whilst all the work was going on each house had to have a tank on a trailer that pumped up the sewage and got replaced every week or two.
As far as I know, my parents had to pay for it all.
So when someone says don't put bleach down the loo, this is what can happen .....
