advise please stick stuff (1 Viewer)
goffer
15
weymouth sunny dorset
c class
2 but tugged for 10
What sticky stuff do you recommend for sticking the plastic beading onto the metail rail around the joints on the van ?
Silicone, Grab fix, super glue ??
Thanks in anticipation. Tony
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
You shouldn't need to stick it on,the bead should hold it in place.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Like Dave said the plastic insert is self supporting.
If ots falling out thes because it has shrunk or gone hard due to age new insert reqiured
If whats been said sound wrong, you have not fully described what your trying to do
Geo
haganap
12,759
26,447
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
I agree with Geo and Dave, I am struggling to understand what you are asking. Are you saying the metal strip to the van has come away? maybe a picture would be a good idea, so you can get the answer you need:thumb:
chrisboyo
1,317
818
Newport South Wales
Autosleepers Sussex Duo
5 + 30 years a tugger
The beading I think you are refering to is called 'erzim' or 'urzim'
I used to use it when I was in shop fiitting for edging trims
the plastic strip usualy just pushes into place in the ali strip, sometimes, if it,s a bit cold we used to leave it in a tub of hot water for a while
It is possable that yours has been got at by old age or u.v.
Check out 'shop fitting supplies' or aluminium edgeing strip, on the internet, you may be able to find a supplier for some new insert strip
Best of luck
Chrisboyo
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Close Chris, its called Herzim and available:-
Link Removed
Terry
11,932
9,083
Lincolnshire
Can't remember ;)
Hi this gives a pic which may help- if not phone them
Link Removed
terry
Scroll down to PVC & Rubber Extrusions
